Si cd player question
I just searched for 45 minutes and didn't find anything. I just put in my old si cd player into my eg and only the screen lit up not the buttons. Should it do this or do I have a blown fuse? Or is it something else?
your harness that plugs into the car should have an ill. wire. hook it to the ill wire on the deck harness, then if the harness that plugs into the carhas a dimmer wire hook the decks dimmer wire to it, if not just ground it. try that and lemme know.
your harness for your radio is missing a wire. the empty slot above the dimmer wire and beside your 12 mem. wire is where the illum + goes. strip a wire and put it in the empty slot. also your car harness does not have the illum wire either. you can tap into the wire in the cars oem harness or the easiest thing to do would be this. put the wire in the empty slot on your radio harness and tie it in with the red acc. wire. then take the dimmer wire thats already in the harness and tie it in with the black ground wire. then the entire face will illuminate with the key. if you want, go to best buy and get the metra reverse harness 71-1721 i belive, as it has both ill., and dimmer wires in it. i have an si cd player in my garage for a shop radio and thats the harness i used and mine lights up perfect. hope this helps. the pictures told all. good luck.
Sylverius
Audio / Security / Video
Jun 27, 2003 12:06 PM
Project_EGG
Jan 1, 2003 11:19 PM
