code 7 TPS wont go away!
Old May 8, 2002 | 07:00 PM
boyracer's Avatar
I think I know. But I really don't
Default code 7 TPS wont go away!
i got a TPS from a different TB (I was told as long as the plug fits it will work)
when you calibrate it it wont go above 3.6V even after making the holes longer
i was told it needed to be 4.5-5v at full throttle
the car runs better (not as rich) but seems, ummmm lean?? dry?? harsh??
i have a b16a
the TB I got the sensor off is MUCH smaller
i also have a field vtc. any history of those making the comp throw codes
go away check engine light, go away
Old May 8, 2002 | 07:28 PM
rainforest's Avatar
Default Re: code 7 TPS wont go away! (boyracer)
check for continuity on all the wires.
Old May 8, 2002 | 09:12 PM
tinkerbell's Avatar
i think you will need a matching TPS for your TB
maybe it doesnt have the right range of movement...
what happend to your old one?
t..
Old May 9, 2002 | 04:23 AM
boyracer's Avatar
Default Re: code 7 TPS wont go away! (rainforest)
What am I checking continuity to, ground, each other...?
It got smashed on the way from japan.
Thanks for you help.
Rainforest what do you drive? I live in Clearwater as well.
Old May 9, 2002 | 05:44 PM
aeolus's Avatar
Try adjustin it at closed throttle with .5 volts instead.Then check to see what you get at WOT.Maybe your throttle is not opening up all the way.......And make sure the leg on the tps sensor is in that little space where its supposed to be.
brandynEG
Engine Management and Tuning
13
Sep 27, 2013 04:51 AM
xander1100
Aug 17, 2009 12:10 AM
AkureiKami
Jul 28, 2009 01:09 PM
MooreBoost
Oct 14, 2002 04:52 PM
