Help taking Crank Pully off
do you have air tools?
if so remove center bolt with impact and 19mm socket.
then pull on crank pulley and be carefull there is a small square keyway that aligns the pulley to the crank.
if the pulley doesn't come off easy then use a 3 or 4 arm pulley puller. if you dont have one rent one at the local parts store.
be careful the lips on the crank pulley will crack if not done right.
if you are not re-using the pulley or are going to throw it away then tap the outside motor side edges of the pulley with a hammer till it pushes off.
only use hammer on pulley if you are NOT re-using the pulley as you will chip the pulley
thanks ill update with what happens!, also i just switched over my flywheel,clutch etc.... over to a LS and everything is together but i noticed that the slave cylender( not sure what its called) the thing that looks like a handle in front of the tranny, well anyways it doesnt move all the way back and forward? feels like its stuck what should i do?
