>>>WHEEL PROBLEM<<<
Old Nov 20, 2006 | 09:28 PM
JDMhon's Avatar
Default >>>WHEEL PROBLEM<<<
ok heres the deal... on my right front rim one of the BOLTS broke off on my teg(someone tried to steal a rim)
so right now i have 3 bolts holding the rim on. what do i have to do to fix it? the stud/bolt doesn't even poke out of the hole. do i have to change the whole right front Assembly?? let me know thanks.
Modified by JDMhon at 12:56 AM 11/21/2006
Old Nov 20, 2006 | 10:13 PM
Blk-dc2's Avatar
Default Re: >>>WHEEL PROBLEM<<< (JDMhon)
it would be easy just to replace the complete assembly...
because you have to press out the bearing , to get the studs out...
Old Nov 20, 2006 | 11:00 PM
Leo C's Avatar
Night Owl
Default Re: >>>WHEEL PROBLEM<<< (BLACK-dc2)
You don't need to replace the entire hub assembly. Any tire/local mechanic should be able to fix this for $30 or so.
Old Nov 20, 2006 | 11:07 PM
Blk-dc2's Avatar
Default Re: >>>WHEEL PROBLEM<<< (Leo.C)
when i had to replace my studs i had to press my bearing out...
how do you get them out with out having to do that
Old Nov 20, 2006 | 11:33 PM
JDMhon's Avatar
so i can go to a goodyear or something? it seems kinda complicated cause BOLT like doesn't even come through the rim. put my steelies on for now..
Old Nov 20, 2006 | 11:36 PM
Leo C's Avatar
Night Owl
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMhon &raquo;</TD></TR><TR><TD CLASS="quote">so i can go to a goodyear or something? it seems kinda complicated cause BOLT like doesn't even come through the rim. put my steelies on for now..</TD></TR></TABLE>
Yes go to any tire dealer and they will replace it for 30-35$
Old Nov 20, 2006 | 11:37 PM
CompanyFlow's Avatar
Get an easy out set and get to work.
Old Nov 20, 2006 | 11:57 PM
JDMhon's Avatar
Default Re: >>>WHEEL PROBLEM<<< (CompanyFlow)
Thanks guys!! i as just dreading goin down to theee junk yard or sumtin and gettin a whole frickin front assembly!! i'll look into it....
76 camaro car
Jan 22, 2015 11:08 AM
lude98SH
Jul 18, 2007 06:02 AM
Dublocivic
Dec 13, 2005 05:46 PM
metal-x
Jun 28, 2004 09:00 AM
96dxB16
Oct 21, 2003 06:46 PM
