Power Window how to
Old May 8, 2002 | 05:52 PM
xci_ed6's Avatar
Default Power Window how to
1: Remove both door panels
-----------DO ONE SIDE AT A TIME
2: Starting with drivers side remove both windows. Roll the window all the way down and look along the lower edge for the 2-10MM bolts holding it.
3: Remove the track there are 4-10 mm bolts around where the crank is and 2 more by the where the arm-rest was on the door panel.
4: The track slides around on wheels, the "mini" track slides around on one. Both are secured with a dent punched in them. drill out the dent and slide the tracks off the wheels. Be carefull to not damage the tracks.
5: Repeat step 4 for the power window unit from a 4 door Civic.
6: Put the mini track and track on the Civic power window unit.
---------NOTE: THE WINDOW "TAB" GOES UP AND TOWARDS THE BACK OF THE DOOR
7: Slide the whole mess into the door.
8: I need a pic of a door with the panel removed-I will circle the holes that are used to mount the power window unit.
9: Run wires through the door. I opted to not have an auto up/down for the driver side so I just ran the red wires through the door.
10: Hook them to switches. Use "DPDT momentary center off" switches. wire like this:
1 to motor
2 to +12V
3 to 4
4 to other motor wire
5 to ground
6 to 1
__________________
|--1-------2--------3--|
|--4-------5--------6--|
|_________________|
11: Repeat for other side
12: Put door panels back on
Please somebody get me a pic of a door with the panel off. Autocratic_1st_Gen@yahoo.com
-Dustin
Old May 8, 2002 | 06:40 PM
xci_ed6's Avatar
Default Re: Power Window how to (Autocratic_1st_Gen)
Oh-Ya, this was all done to DJ0820's 89 CRX Dx
-Dustin
Old May 9, 2002 | 01:59 PM
Speed PHreak's Avatar
Along with my 93 Sohc Vtec head, i'm picking up the power locks/windows froms a 91 LX. I'm interested in any thing you can share. I"m sure quite a few guys would like to have some "powa" accessories on their crx's
Old May 13, 2002 | 06:34 AM
Default Re: Power Window how to (Speed PHreak)
Power window bolt pattern. I just did this swap over the weekend and I love it!
Just a sub-note to your write up. Add some grease to those rails when you've got them apart. The little wheel will self-destruct if they're not greased for a long time. Mine were like that on my manual assmbly when I did the drivers side.
[Modified by Speed PHreak, 3:37 PM 5/13/2002]
Old May 13, 2002 | 07:49 AM
xci_ed6's Avatar
Not quite the best pic to explain this, but basically, yeah.
-Dustin
Old May 13, 2002 | 07:52 AM
Sorry best thing I could come up with. I forgot to take pisture when I was doing the swap on mine. Putting the windows in was easy. Routing the wiring ws a pain in the ***.
Old May 13, 2002 | 10:45 AM
xci_ed6's Avatar
I'll try my hand at ASCII. Ignore the "---"
Manual:
---o-----------
-----------o---
----------O---
-----------o---
---o-----------
Power:
--x-------------------
--------------------o-
-----------------O----
o=bolt holes
x=use a spacer between the door and the module for these holes
O=where the crank handle goes.
If you look around the holes are already drilled. They are not used for anything else.
-Dustin
Old Oct 9, 2003 | 09:48 PM
allmotaR's Avatar
Default Re: Power Window how to (krustindumm)
Im in the process of doing this to my EG hb si. I got all the componets and **** in the door...and i ran it str8 to power to manuver the mechanics up and down so i could install my window, then rolled it back up. However I need to know what wires to connect to my old ones running from where the wires go into the frame behind the fender. I have all the hardware and wires and everything, but it does'nt plug and play so i have to use the wiring from the ex. Any one can help??? please let me know. thanks
Old Oct 9, 2003 | 10:54 PM
Smokinsax's Avatar
The Boot
Default Re: Power Window how to (dohc-vtec-206)
Good job on the write up
Old Oct 10, 2003 | 06:48 PM
RiceRacist's Avatar
Default Re: Power Window how to (Smokinsax)
Could you list all the things I will need to pick up from the junkyard to get powa windows?
What car is it best to look for
Old Oct 10, 2003 | 08:16 PM
jdmhondageek's Avatar
Default Re: Power Window how to (RiceRacist)
Im stupid and cant read.... my bad.
Modified by jdmhondageek at 2:42 AM 10/11/2003
Old Oct 10, 2003 | 09:23 PM
xci_ed6's Avatar
Default Re: Power Window how to (jdmhondageek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhondageek &raquo;</TD></TR><TR><TD CLASS="quote">
JDM yo. nothing else will do... unless you want to go aftermarket. </TD></TR></TABLE>
******* wrong. read my post bitch (I was Autocratic_1st_Gen).
The front door motors from any 88-91 4D are known to work, others may, try at your own risk. I was told that the rear windows also go all the way down, so those are probably a good chance.
-Dustin
ImportHatch's Avatar
I was under the impression that the EF 4 dr power windows would work in a CRX. Anyone know for sure...cause now im gettin mixed signals.
Yager-
Old Oct 10, 2003 | 09:38 PM
xci_ed6's Avatar
Default Re: Power Window how to (ImportHatch)
did you read the beggineng at all???
I ******* did it!!!!!!!!!!!
Yes they work!!!!!!!!!!!!
God damn, there is a power window thread every ******* week!
-Dustin
Old Oct 11, 2003 | 12:29 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">did you read the beggineng at all???
-Dustin</TD></TR></TABLE>
If you noticed, we posted at almost exactly the same time, and I was referring to the guys post above mine, saying jdm only **** like that.
Yager-
Old Oct 11, 2003 | 06:45 AM
xci_ed6's Avatar
uhhh, sorry, i was tired and so i got pissed at everything.
-Dustin
Tomas P
Apr 6, 2012 12:06 AM
sleepyhead87
13
Jan 1, 2010 10:48 PM
Lightsped
Aug 28, 2008 11:14 AM
meandmy
Dec 2, 2005 10:01 AM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
