LIL VAC BOX I MADE.....
Old Nov 20, 2006 | 04:44 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default LIL VAC BOX I MADE.....
MADE THIS VAC BOX FOR MY TURBO SOHC..
ALL ALUMINUM...
CUT HERE CUT THERE WELD HERE DRILL THERE...POWDER COATED IT BLACK
DID IT ALL AT WORK...
BOOM..
Old Nov 21, 2006 | 06:25 AM
fventura03's Avatar
nice
Old Nov 21, 2006 | 08:18 AM
Fo-Do Fanatic's Avatar
Default Re: (fventura03)
its pretty nice man. good job. it would've been a bit cooler if all the fittings on it were straight and equal length.
Old Nov 21, 2006 | 09:49 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (b00sted-Hatch)
Ya I happened to be leaning so I wasn't cutting str8... Ill fix that before I install it
Old Nov 21, 2006 | 11:42 AM
fventura03's Avatar
are you going to install it behind the firewall?
Old Nov 21, 2006 | 12:36 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Nah just in a low position near the cross member
Old Nov 21, 2006 | 04:43 PM
boosted94cx's Avatar
* B A N N E D *
it woudl have looked better if you had just drilled/tapped the fitting instead of welding them. it looks cheap. and at least with tapped holes, you can run an fittings that look professional and hold up better than just a hose/clamp setup
but...a for effort for sure
Old Nov 21, 2006 | 06:40 PM
VRD^don's Avatar
Default Re: (boosted94cx)
you should of made some tabs so that u can bolt it some where...instead of having it hanging in the bay...
Old Nov 21, 2006 | 08:45 PM
SL0WEGG's Avatar
Default Re: (k_motor)
why didnt you just buy one? those things are cheap as hell . But i guess diy FTW!!
Old Nov 22, 2006 | 05:59 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: (boostedej1)
i was going to make a bracket so i can bolt it up but didnt bother with it...
y i didnt buy one... why bother if i can just make one at work.
didnt buy fittings for that same reason..
i was bored at work so i made it...
Old Nov 22, 2006 | 01:00 PM
deryck324's Avatar
Default Re: (S@nt0s)
why didnt you just tap into it and use vacume fittings like people use on the golden eagle vacume manifold or use an fittings
Old Nov 22, 2006 | 02:31 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deryck324 &raquo;</TD></TR><TR><TD CLASS="quote">why didnt you just tap into it and use vacume fittings like people use on the golden eagle vacume manifold or use an fittings</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S@nt0s &raquo;</TD></TR><TR><TD CLASS="quote">i was going to make a bracket so i can bolt it up but didnt bother with it...
crxaddikt
Oct 16, 2011 08:37 PM
2000gsr-dragon
Audio / Security / Video
14
Mar 22, 2010 11:52 AM
dizzyek
Nov 16, 2006 04:38 PM
TnTWRX
15
Jun 28, 2004 06:38 AM
xXxS_SxXx
21
Mar 15, 2003 11:55 PM
