400 whp on b16 turbo....
Old Nov 20, 2006 | 02:53 PM
pearlcfcivic97's Avatar
Default 400 whp on b16 turbo....
i have a b16 with all stock internals and it burns oil so i have to fix the block, and i might as well build it while im at it....
here is what i was thinking. this is with help from the local tuner shop....tell me what you all think
Block:
b16 block
with either srp pistons or je pistons
eagle h-beam rods
new oil pump, water pump and timing belt
Head:
Crowler chromale retainers
dual valve springs
valve job
Turbo:
precision dual ball bearing turbo sc34 with a .48 exhaust side(hot side)
edlebrock victor x intake manifold
mini me exhaust manifold
custom piping and some sort of FMIC....
tuned with hondata
and here are the prices...
2500 to build the block...
1500 to do the head....
so 4,000 to build the whole motor ready for turbo, this is installed in my car....
so while im saving up for the turbo im breaking in the built motor
and then 4,000 more to build the whole turbo, put it on, and tuned with hondata and on the dyno....
So let me know your opinions, suggestions, and if this is WAY to much money to reach 400 whp.....thats what the shop is guessing....either close to 400 or at 400!!!!
Old Nov 20, 2006 | 02:55 PM
cambopheonix56's Avatar
Default Re: 400 whp on b16 turbo.... (pearlcfcivic)
Can the stock sleaves hold 400whp?
Old Nov 20, 2006 | 03:00 PM
jdm_eg06's Avatar
Boom....careful what you wish for, and don't ignore what cambopheonix56 just said.
Old Nov 20, 2006 | 03:02 PM
Default Re: (jdm_eg06)
http://forums.evans-tuning.com...=4065
I mean I guess it could, but for how long.
Old Nov 20, 2006 | 03:47 PM
Throwdown's Avatar
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
Default Re: (cambopheonix56)
yes i've seen them hold...right over 400 but you need a good tune to do it....i think it is pushing it though .... sleeve it be safe
Old Nov 20, 2006 | 03:49 PM
Default Re: (DBL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBL &raquo;</TD></TR><TR><TD CLASS="quote">yes i've seen them hold...right over 400 but you need a good tune to do it....i think it is pushing it though .... sleeve it be safe </TD></TR></TABLE>
Yea sleeve it and go for 500whp.
EH6TunerDaniel's Avatar
You are missing a lot of parts in your list there man.
Old Nov 20, 2006 | 04:28 PM
dafuzzbudd's Avatar
Default Re: (EH6TunerDaniel)
he seems to have the basics.
sleeving should be a MUST for pushing that much hp
it would be stupid to let your engine go boom after all that $$
when sleeves could have helped prevent
Old Nov 20, 2006 | 04:39 PM
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EH6TunerDaniel &raquo;</TD></TR><TR><TD CLASS="quote">You are missing a lot of parts in your list there man.</TD></TR></TABLE>I can't believe he forgot jdm vtak fluid.
Old Nov 20, 2006 | 05:30 PM
Apparently he is not worried about running out of fuel...Rod bolts and head bolts should be included...He doesnt need cams or anything else. Hmmm, should hit 400+ whp EASY.
Old Nov 20, 2006 | 05:56 PM
platinumx6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pearlcfcivic &raquo;</TD></TR><TR><TD CLASS="quote">
Block:u already got
b16 block
eagle h-beam rods &lt;doesnt the block need notching with these? not sure on B's
new oil pump, water pump and timing belt &lt; OEM for sure
Head:
dual valve springs
valve job
Turbo:
precision dual ball bearing turbo sc34 with a .48 exhaust side(hot side)&lt; i think your gunna need a bigger one
tuned with hondata
2500 to build the block... &lt;pistons/rods wont cost that much, plus parts shouldnt cost that much. Does this include hot tanked/put together/ or blueprinting??
1500 to do the head.... &lt;you can do better
So let me know your opinions, suggestions, and if this is WAY to much money to reach 400 whp.....thats what the shop is guessing....either close to 400 or at 400!!!!</TD></TR></TABLE>
Is this a DD or what? Im not sure on the b16 but with 400hp you probably need to sleeve it for reliability. $1k
What is this in? Your gunna need a lot of help to get 400 to the ground, traction is gunna kill you.
obx LSD- ~$400??
GOOD TIRES, if this isnt for the strip. $$$ mroe then normal!
Fuel management??
750cc injectors- RC's $350
I dunna but i think your gunna spend more then 5k to effectively and reliably get 400hp from that 1.6l
hope i was helpfull. Feel free to correct my mistakes honda guru's
Old Nov 21, 2006 | 11:33 AM
platinumx6's Avatar
edited with some EBAY pricing.
Old Nov 21, 2006 | 01:37 PM
8krdline's Avatar
Default Re: (platinumx6)
bigger turbo would make it much easier
Old Nov 21, 2006 | 03:26 PM
chippy's Avatar
Default Re: (8krdline)
there are so many.. I WANT TO BUILD threads.. i use to do this too, untill i said hey i'll stop dreaming and start buying lols.
Old Nov 21, 2006 | 03:38 PM
slambedcivic's Avatar
Default Re: (chippy)
thats a small turbo for 400 whp.
and im shooting for 375-400 on stock sleeved. bored. but with a block gaurd
Old Nov 23, 2006 | 04:19 PM
platinumx6's Avatar
Default Re: (slambedcivic)
^^wait, lol...bored and sleeved with stock rods/pistons? lol
Old Nov 26, 2006 | 03:02 PM
Yeah I just noticed that my friend posted this **** up on my account, so dont relate anything that was said to this screen name... Im all about k series
Old Nov 27, 2006 | 10:16 PM
dafuzzbudd's Avatar
Default Re: (pearlcfcivic)
blockguards interfere with cooling
i would advise against it
Old Nov 27, 2006 | 10:34 PM
deryck324's Avatar
if anything he will blow a head gasket before cracking a sleve
Old Nov 27, 2006 | 10:38 PM
97tnsir's Avatar
damn, seems kinda pricey to me
Old Nov 27, 2006 | 11:55 PM
fmrprojects's Avatar
Default Re: 400 whp on b16 turbo.... (97tnsir)
why do a b16. might as well get a LS block or gsr and build that up
Old Nov 28, 2006 | 04:56 AM
blaze the chemi's Avatar
Default Re: 400 whp on b16 turbo.... (fmrprojects)
Send your block to Earl. Period. End of story.
https://honda-tech.com/zerothread?id=848849
Old Nov 28, 2006 | 06:25 AM
MrRealityman's Avatar
Default Re: 400 whp on b16 turbo.... (blaze the chemi)
hell for $8000 i'd go with a jrsc b18c5 or build a rippin' b20vtec
00CivicSi5spd
Jan 9, 2018 06:48 AM
jdmctr18
Aug 5, 2014 06:20 PM
lickety_britches
May 28, 2008 09:24 PM
teamsoy1320
Jul 23, 2006 11:08 AM
Nextelbuddy
17
Jun 27, 2003 08:35 AM
