--------------------------------------------------------------------------------tranny
Old Nov 20, 2006 | 09:37 AM
hspoon's Avatar
Default --------------------------------------------------------------------------------tranny
am not gettin pressure on the clutch pedal i already replace the master clutch culinder and clutch kit,,,, but still cant shift gears without the clutch,,, but tranny still works because i can still shift gears... anything could help... thanx
Old Nov 20, 2006 | 09:41 AM
Bense's Avatar
you sure?
Old Nov 20, 2006 | 09:42 AM
hspoon's Avatar
sure of what???
Old Nov 20, 2006 | 09:50 AM
EE_Chris's Avatar
Default Re: (hspoon)
Did you bleed the clutch again? Get a second set of eyes, push down the clutch and see if the slave cylinder is moving.
Old Nov 20, 2006 | 09:52 AM
CodyC142's Avatar
Default Re: (EE_Chris)
whats it mean if the slave cyclinder moves?
Old Nov 20, 2006 | 10:29 AM
hspoon's Avatar
the master cylinder its new... but its kinda leakin so i really dont know if could be a problem and im about to replace it...
Old Nov 20, 2006 | 10:34 AM
EE_Chris's Avatar
Default Re: (CodyC142)
It's a starting point. It sounds like he's saying he can shift gears but only when the engine is off and can't with it on because the clutch might not be getting disengaged. If that's the case, is the slave cylinder actually moving when pressing the clutch pedal?
Old Nov 20, 2006 | 10:38 AM
Archidictus's Avatar
Unceasing Measure
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hspoon &raquo;</TD></TR><TR><TD CLASS="quote">the master cylinder its new... but its kinda leakin so i really dont know if could be a problem and im about to replace it...</TD></TR></TABLE>
Is it "kinda leakin" or is it leaking? This isn't a maybe-kind-of-question. If you're losing fluid in the system, then you're losing pressure and you won't be able to disengage the clutch. This is not rocket science, it's a simple "look...there's fluid, I'll fix the leak" issue.
And you're ******* retarded for the thread title you used. Moron.
jentee
Jun 15, 2008 09:21 PM
blacklsvtec24
Apr 3, 2008 12:04 PM
typerekb16
Dec 19, 2006 08:43 AM
bambbrose
Jul 6, 2005 12:46 PM
k-man
Jul 24, 2003 07:04 AM
