Anybody ever snap a quaife?
Old Nov 19, 2006 | 08:17 PM
silverboost's Avatar
Default Anybody ever snap a quaife?
i think i snapped my differential, its a quaife lsd and after beating on the car everytime the wheels turb theres a grinding/snapping noise, the axels and clutch are both fine, it does it in neutral as well. has this happened before? I know they are really good and have lifetime warranty.
Old Nov 20, 2006 | 02:31 PM
Default Re: Anybody ever snap a quaife? (silverboost)
bump
Old Nov 20, 2006 | 03:52 PM
Jared's Avatar
are you sure the axles are ok? ive beat the **** out of my quaife and never hurt it. hundreds of 7k launches on 25" slicks.
Old Nov 20, 2006 | 06:38 PM
yea driveshaft shop axels and they both look good, when it broke i was on th highway, didnt launch the car all day
Old Nov 20, 2006 | 06:44 PM
Jared's Avatar
looking at an axles is no indication of whether it is ok or not. what happend on the highway?
Old Nov 21, 2006 | 10:45 AM
Default Re: (Jared)
i was driving on the highway and ran the car hard, i came to my exit, and accellerated to the end of 2nd gear and then it starting acting up, so i pulled over
Old Nov 21, 2006 | 12:53 PM
Jared's Avatar
Default Re: (silverboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost &raquo;</TD></TR><TR><TD CLASS="quote">i was driving on the highway and ran the car hard, i came to my exit, and accellerated to the end of 2nd gear and then it starting acting up, so i pulled over</TD></TR></TABLE>
describe "acting up"
Old Nov 21, 2006 | 08:48 PM
meaning grinding every time the tire spun over once, grinding and both wheels shaking or snapping, in nuetral and in gear, clutch is engaging fine
Old Nov 21, 2006 | 08:56 PM
VRD^don's Avatar
hmmm...sounds like wheel bearings to me.....
Old Nov 21, 2006 | 08:57 PM
VRD^don's Avatar
Default Re: (k_motor)
wait..does this shaking, snapping occurs when car is in neutral while at dead stop or while moving???
Old Nov 22, 2006 | 04:26 PM
only when moving, pushed the car in neutral and wether car is started, or no, it still does it
Old Nov 22, 2006 | 08:35 PM
VRD^don's Avatar
wheel bearings..
Old Nov 23, 2006 | 07:29 AM
wheel bearings are new have about 5k miles on them
Old Nov 23, 2006 | 07:41 AM
Flashmn's Avatar
Doesn't matter, I've seen wheel bearings go within 1000miles, when they were improperly installed (too tight).
Old Nov 23, 2006 | 09:16 AM
loudassVTEC's Avatar
Default Re: (Flashmn)
Jack up the front, and try to move the tire in an up, and down motion. If you feel play (you'll hear it click to), or if the wheel feels loose, its the bearings. YOu might want to check the axles. Sometimes the boots will looks fine, but everything inside is fubar'd. It doesn't sound like a doff problem. Normally when you snap the diff(or at least the two that I've personally seen), it blows a hole through the case, and tranny fluid goes everywhere. And if you try to drive the car, it won't go anywhere, and you can shift gears while sitting still. The speedo climbs, and the car is stationary. It might not be like that everytime, but my friend has blown his LS trans diff like 3 times, and this happened everytime.
Old Dec 6, 2006 | 08:28 PM
dropped the tranny and the wheels move fine w/o axels its not the bearings or axels, sumthing in the tranny, sent for rebuild
Old Dec 7, 2006 | 04:35 PM
That ****** sucks. Keep up posted on what the problem was. I'm curious to see if its the diff.
Old Dec 7, 2006 | 06:14 PM
Dogginator's Avatar
Daisy... Daisy...
What was the tranny fluid level?
Old Dec 10, 2006 | 01:22 PM
fluid level was fine, no shavings in oil, looked like new. Once i get the tranny bak ill post the problem
Old Feb 9, 2007 | 07:35 AM
*update*
ring gear was shot and fell apart, also the gears were worn out. New tranny and car is fine. Quaiffe was also fine.
Old Feb 9, 2007 | 08:44 AM
trickeng's Avatar
good that it wasn't your quaife. i broke one and they fixed it for free but it took 4months to get it back.
Old Feb 9, 2007 | 10:12 PM
Default Re: (trickeng)
yea i had no worriesw about them replacing it, but i finally have my eg back on the road
Old Feb 10, 2007 | 11:30 AM
Blown90hatcH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">good that it wasn't your quaife. i broke one and they fixed it for free but it took 4months to get it back.
Wierd. I have never had an issue when sending in a quaife unit for inspection/repair.
Glad you got your car back on the road.
EKJACE
15
May 29, 2011 09:52 PM
crx00
Sep 19, 2007 08:50 AM
JDM_Ej
Dec 22, 2005 03:16 AM
hondapwr
24
May 19, 2005 01:39 PM
Apollo
May 4, 2004 05:14 PM
