B18B valve adjustment- where to take the measurement?
Old Nov 19, 2006 | 12:06 PM
DC4_MADMAN's Avatar
Default B18B valve adjustment- where to take the measurement?
I did search "b18b valve" and got all the specs I could ever need and all sorts of valve cover ****, but no thread about WHERE the measurement is taken.
The rocker arm U shapes over the valve stem head, so do I take the measurement between rocker arm and cam lobe?
Old Nov 19, 2006 | 12:39 PM
DB1_559's Avatar
Default Re: B18B valve adjustment- where to take the measurement? (DC4_MADMAN)
rocker arm and cam lobe it should be a easier way let me see if i can remember
step by step on tdc you adjust piston 1 7mm for intake 6m for exhaust ,crank 25%
and go to piston 3 than 4 than 2
Old Nov 19, 2006 | 01:08 PM
DC4_MADMAN's Avatar
Default Re: B18B valve adjustment- where to take the measurement? (jdmboi86)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmboi86 &raquo;</TD></TR><TR><TD CLASS="quote">rocker arm and cam lobe it should be a easier way let me see if i can remember
and go to piston 3 than 4 than 2 </TD></TR></TABLE>
Thanks.
Old Nov 19, 2006 | 01:41 PM
95 integra's Avatar
BTW, when changing cylinders you have to crank the crank pulley over half a turn (cam pulley 1/4 turn).
Old Nov 19, 2006 | 02:34 PM
DC4_MADMAN's Avatar
Default Re: B18B valve adjustment- where to take the measurement? (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">BTW, when changing cylinders you have to crank the crank pulley over half a turn (cam pulley 1/4 turn).</TD></TR></TABLE>
Yes, I have a remote start switch to do this.
Old Nov 19, 2006 | 02:46 PM
95 integra's Avatar
It turns it exactly half a turn?
Old Nov 19, 2006 | 02:49 PM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">It turns it exactly half a turn?</TD></TR></TABLE>
Its used to bump the starter so that you can get the timing marks to line up.
Old Nov 19, 2006 | 03:13 PM
95 integra's Avatar
Yea, you'll never get it exactly dead up using that method.
Old Nov 19, 2006 | 03:16 PM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">Yea, you'll never get it exactly dead up using that method. </TD></TR></TABLE>
Well seeing as I attempted to do by hand already(very difficult to gain leverage with car on ground) Ill take my chances. Ill know in a few days. Also this was the way recomended.
Old Nov 19, 2006 | 03:31 PM
KaBlookie's Avatar
This will tell you pretty much everything you need to know to do a valve lash adjustment on your teg. I just did mine yesterday.
here are the proper clearances:
B18A
INTAKE: 0.006" - 0.007" (0.15mm - 0.19mm)
EXHAUST: 0.007" - 0.008" (0.17mm - 0.21mm)
B18B
INTAKE: 0.003" - 0.005" (0.08mm - 0.12mm)
EXHAUST: 0.006" - 0.008" (0.16mm - 0.20mm)
B18C
Old Nov 19, 2006 | 06:22 PM
DB1_559's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KaBlookie &raquo;</TD></TR><TR><TD CLASS="quote">This will tell you pretty much everything you need to know to do a valve lash adjustment on your teg. I just did mine yesterday.
B18A
B18B
B18C
EXHAUST: 0.007" - 0.008" (0.17mm - 0.21mm)</TD></TR></TABLE>
i thought b18b/a isthe same specs but its 6mm for intake and 7mm for exhaust my bad
Old Nov 20, 2006 | 04:36 PM
KaBlookie's Avatar
well if I'm not mistaken, those numbers were taken from the Helm's manual...someone correct me if I'm wrong, but I'm pretty sure that's where they came from.
mattyrocks785
May 19, 2012 07:11 PM
djhatchtraxxx89
Oct 4, 2006 03:46 PM
Atheist
Aug 10, 2004 07:40 AM
HmgLauj69
Feb 25, 2004 06:03 PM
LshatchTurbo
Aug 12, 2002 03:28 PM
