ls vtec questions...
Old Nov 18, 2006 | 05:56 PM
e she i's Avatar
Default ls vtec questions...
im bout to do me a ls vtec set-up and got afew questions...im using a b16 head w/ a ls bottom and was wondering which head gasket,headstuds,and timing belt to use..i was told to use the headgasket,headstuds,timing belt,water pump of which head im gonna be using...so i just wanna see if that is true or not...
Old Nov 19, 2006 | 05:04 AM
e she i's Avatar
Default Re: ls vtec questions... (e she i)
bump...need the info
Old Nov 19, 2006 | 12:00 PM
funk.regulator's Avatar
ls head gasket, ebay dowl pins for the ls/vtec swap ($10), gsr head studs, get a gsr water pump, timing belt and oil pump.
I built one mysef and its still runnning strong. Any questions, search than ask.
Old Nov 19, 2006 | 02:33 PM
B e v - T e c h I n c.'s Avatar
You don't have to use any different dowl pins, just drill out the head bolt holes in the correct place to accept the original dowls, also be sure to plug the oil passage in the head. You don't "have" to change your oil pup either, but it help with the high RPM's. and just be sure to match the belt with the waterpump.
Old Nov 19, 2006 | 03:10 PM
mmuller's Avatar
Mad Scientist
Default Re: ls vtec questions... (funk.regulator)
use a vtec waterpump; since the non-vtec one cavitates at around 7500 rpms
Old Nov 19, 2006 | 04:09 PM
e she i's Avatar
Default Re: ls vtec questions... (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by funk.regulator &raquo;</TD></TR><TR><TD CLASS="quote">ls head gasket, ebay dowl pins for the ls/vtec swap ($10), gsr head studs, get a gsr water pump, timing belt and oil pump.
I built one mysef and its still runnning strong. Any questions, search than ask.</TD></TR></TABLE>
oh ok...thanks guys
804tuned
Engine Management and Tuning
Feb 17, 2009 01:28 PM
Fezzie
Dec 13, 2006 03:40 PM
shoebox
Sep 11, 2006 09:07 AM
boosted92hatch
May 29, 2006 08:44 AM
GEN2INTEG619
Mar 27, 2005 04:57 PM
