Removing Bumber - small bolt is a bitch. Need help.
Old Nov 18, 2006 | 01:46 PM
Flux's Avatar
Default Removing Bumber - small bolt is a bitch. Need help.
Just removing the front bumper and one of the bolts isn't not coming out. It isn't stuck, it just spins and spins but will not come out of there. The bolt I am talking about is pictured in the left photo below. (thanks team-integra.net).
Any ideas on how to get this out of there?
Old Nov 18, 2006 | 02:01 PM
BMaDOHC's Avatar
Default Re: Removing Bumber - small bolt is a bitch. Need help. (Flux)
try jamming a flat head punch or screwdriver under the head of the bolt. use pressure while turning bolt and some wd40
Old Nov 18, 2006 | 03:04 PM
Erik95LS's Avatar
Default Re: Removing Bumber - small bolt is a bitch. Need help. (BMaDOHC)
Its possible someone stripped out the the factory threads and theres a nut on the other side. Have you checked that?
Old Nov 18, 2006 | 06:14 PM
dsav4shawn's Avatar
Default Re: Removing Bumber - small bolt is a bitch. Need help. (Erik95LS)
I'm thinking that the small bolt is a bitch because your nuts are too small.
-I could be wrong. (just apply upward force like the other guy said).
Old Nov 18, 2006 | 06:33 PM
. a d a m's Avatar
Default Re: Removing Bumber - small bolt is a bitch. Need help. (dsav4shawn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsav4shawn &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking that the small bolt is a bitch because your nuts are too small.
-I could be wrong. (just apply upward force like the other guy said).</TD></TR></TABLE>
LOL
Yeah try the screwdriver thing
Old Nov 18, 2006 | 09:10 PM
John M's Avatar
-I could be wrong. (just apply upward force like the other guy said).</TD></TR></TABLE>i loled when i saw that
Old Nov 18, 2006 | 09:13 PM
kiddcarbuff's Avatar
for those i dont waste any time w/ a phillips head, i grab a vise grip and put it on the head of the screw, lock it, and twist it out
Old Nov 18, 2006 | 09:27 PM
bg-33p's Avatar
Default Re: (kiddcarbuff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsav4shawn &raquo;</TD></TR><TR><TD CLASS="quote">your nuts are too small.</TD></TR></TABLE>
lmfao ahah, well yeah i had this problem too. I used as much pressure as a could and if possible push it out from the bottom.
Old Nov 18, 2006 | 09:57 PM
markpaco's Avatar
use an impact driver. The same thing you use on your brake rotors.
As for the bolt...not sure. Try remove all the other fasteners first and if you still can't get the bumper cover off, drill that bolt out.
Old Nov 18, 2006 | 10:03 PM
Erik95LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kiddcarbuff &raquo;</TD></TR><TR><TD CLASS="quote">for those i dont waste any time w/ a phillips head, i grab a vise grip and put it on the head of the screw, lock it, and twist it out</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markpaco &raquo;</TD></TR><TR><TD CLASS="quote">use an impact driver. The same thing you use on your brake rotors.
As for the bolt...not sure. Try remove all the other fasteners first and if you still can't get the bumper cover off, drill that bolt out.</TD></TR></TABLE>
he's not working on the screw guys.......just the bolt.
Old Nov 18, 2006 | 10:10 PM
bg-33p's Avatar
Default Re: (Erik95LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Erik95LS &raquo;</TD></TR><TR><TD CLASS="quote">he's not working on the screw guys.......just the bolt. </TD></TR></TABLE>
if it's just the bolt take a wrench and pry it out with force.
Old Nov 19, 2006 | 10:38 AM
MilFhunter001's Avatar
Default Re: (teggysue)
If i have a problem like that. I get a drill with a bit tad smaller than the head of the bolt and let er rip.
Old Nov 19, 2006 | 01:01 PM
Flux's Avatar
Default Re: (MilFhunter001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilFhunter001 &raquo;</TD></TR><TR><TD CLASS="quote"> If i have a problem like that. I get a drill with a bit tad smaller than the head of the bolt and let er rip.</TD></TR></TABLE>
that is what I am about to do...
Old Nov 19, 2006 | 04:30 PM
vtec.dc2's Avatar
these bolst are easy to strip. make sure to apply enough pressure as you try to turn it. and use thick enough screw driver.. as mentioned.. use some type of rust spray
Old Nov 19, 2006 | 06:47 PM
VISEGRIPS FTW!
Old Nov 19, 2006 | 07:03 PM
hayabusa160's Avatar
you have to use a pretty big philips head for those. i usually use a hammer and give it a few wacks with the screw driver on it so it have a nice bite in to it. if that dont work go grab the vice grips. i hate those screws alot.
Old Nov 19, 2006 | 09:29 PM
GOOCH-JDM-ITR's Avatar
Default Re: (hayabusa160)
drill it out with a small bit and work your way up. drill out old screw and retap
Old Nov 19, 2006 | 09:35 PM
project.one's Avatar
New User
Default Re: (GOOCH-JDM-ITR)
this is what you need:
works everytime.
Old Nov 20, 2006 | 06:55 AM
Flux's Avatar
Default Re: (project.one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project.one &raquo;</TD></TR><TR><TD CLASS="quote">this is what you need:
works everytime. </TD></TR></TABLE>
LOL.. that is what finally worked yesterday...
spidermancivic
Aug 11, 2007 08:17 AM
EFstyle
23
Jan 27, 2007 10:49 PM
spidermancivic
Oct 5, 2006 10:10 PM
spidermancivic
Oct 3, 2006 09:41 PM
Layziebtnh055
May 14, 2004 06:42 AM
