spoiler rubbing
Old Nov 18, 2006 | 09:43 AM
nonvteclude's Avatar
Default spoiler rubbing
is anyone else having this problem? the spoiler is rubbing on the rear panel and the trunk is adj all the way up. looking at other ludes the spoiler does not touch. any ideas? oh and excuse the dirty car i live in denver its hard to keep any car clean
Old Nov 18, 2006 | 12:45 PM
94Vtecluder's Avatar
Default Re: spoiler rubbing (nonvteclude)
I've never seen that. Mine has plenty of clearance. Has some fatass been sittin on that? Maybe you can shim it up or something.
Old Nov 18, 2006 | 12:50 PM
GraphiteMW's Avatar
Default Re: spoiler rubbing (94Vtecluder)
Time for a new wing, someone has been sitting on it.
Old Nov 18, 2006 | 01:25 PM
axlline's Avatar
Default Re: spoiler rubbing (GraphiteMW)
it just mounted to far forward
Old Nov 18, 2006 | 08:40 PM
DfwBB6's Avatar
if you cant move it back a lil bit just put like some washers or sumptin to raise it
Old Nov 19, 2006 | 06:55 AM
prelude_h22vtec's Avatar
does the trunk line up right? has it been taken off before?
btw, your car is dirty lol
Old Nov 19, 2006 | 10:12 AM
M@'s Avatar
M@
Default Re: (prelude_h22vtec)
Maybe its missing the gasket the goes between the trunk, and the spoiler. Find another gasket and use that as a spacer.
Old Nov 19, 2006 | 06:05 PM
Default Re: (M@)
the spoilr has been this way since i bought the car back in 03. i have replaced the gasket between the spoiler in the trunk and still does it. the trunk is adj all the way up and is in stock location. it is a problem on both sides. so not sure what it is
Old Nov 19, 2006 | 07:11 PM
M@'s Avatar
M@
Default Re: (nonvteclude)
I think you mean adjusted all the way up as in when the trunk is open it is as high as it will go, but if you mean forward then I think that would be a problem.
You should take more pictures of the trunk closed. That can only help.
Old Nov 19, 2006 | 07:36 PM
Default Re: (M@)
yes that is what i meant, the spoiler is as far back as it goes. i will take more tomorrow
PowerLeg
Sep 10, 2009 11:28 PM
BumbleBee Tuna
11
Jun 23, 2008 03:58 PM
JDMPaulWall
Jul 9, 2006 02:42 PM
FK00GSR
May 25, 2005 10:59 AM
lilbastrd
Honda S2000
57
Mar 8, 2005 09:16 PM
