Head gasket re-use question
Old Nov 17, 2006 | 04:04 PM
djnikko's Avatar
Default Head gasket re-use question
I have my h22 all built up and have decided to have a little more headwork done the problem is the gasket has been used but for zero miles if that makes sense i.e. crushed. It is a cometic stainless steel gasket. Im running forced induction and darton sleeves if that makes any odds
Old Nov 17, 2006 | 07:05 PM
DiRty96's Avatar
Default Re: Head gasket re-use question (djnikko)
replace it!
Old Nov 17, 2006 | 08:48 PM
89s1's Avatar
Default Re: Head gasket re-use question (DiRty96)
not worth the risk a crushed headgasket seals as good as the cardboard sheet it was packaged on.
Old Nov 18, 2006 | 04:13 PM
0554's Avatar
replace it.
Old Nov 19, 2006 | 07:46 AM
white90rexsi's Avatar
Default Re: Head gasket re-use question (.EnzoSpeed)
Once the gasket has been torqued its done. Its a 1 time use deal, dont be cheap and try to reuse it.
Old Nov 19, 2006 | 12:21 PM
ek_chris's Avatar
You got a fully built motor under boost, and you want to re-use a HG? DOn't be stupid
Old Nov 20, 2006 | 02:22 AM
b18sihatch's Avatar
new
Old Nov 20, 2006 | 06:38 AM
s10cky's Avatar
Default Re: (ek_chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_chris &raquo;</TD></TR><TR><TD CLASS="quote">You got a fully built motor under boost, and you want to re-use a HG? DOn't be stupid</TD></TR></TABLE>
Old Nov 20, 2006 | 07:42 AM
djnikko's Avatar
Default Re: (s10cky)
Thanks for the replies guys. I do have a brand new motor factors head gasket I guess my question should have been, brand new motor factors headgasket or used cometic headgasket.
does the fact its stainless steel make any odds? Im sure I read somewhere the cometic gaskets can be re used.
The block has been decked and the head has been skimmed if that makes any odds.
Im going to go with a new headgasket anyhows
Old Nov 20, 2006 | 01:49 PM
.EnzoSpeed.'s Avatar
Default Re: (djnikko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djnikko &raquo;</TD></TR><TR><TD CLASS="quote"> Im sure I read somewhere the cometic gaskets can be re used.
Any head gasket can be re-used, I've seen it done several times. People just like to tell you the correct way to do things, which in this case, would be to use the new gasket.
Old Nov 20, 2006 | 08:50 PM
ITR#132's Avatar
Default Re: (.EnzoSpeed.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .EnzoSpeed. &raquo;</TD></TR><TR><TD CLASS="quote">
Any head gasket can be re-used, I've seen it done several times. People just like to tell you the correct way to do things, which in this case, would be to use the new gasket.</TD></TR></TABLE>
Yup, I also have re-used headgaskets before without any problems.
Old Nov 21, 2006 | 06:33 PM
TurboTeG4's Avatar
Default Re: (ITR#132)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR#132 &raquo;</TD></TR><TR><TD CLASS="quote">
Yup, I also have re-used headgaskets before without any problems.</TD></TR></TABLE>Seems like a chance thats up to you to take
Old Nov 22, 2006 | 08:36 AM
d16dcoe45's Avatar
Default Re: (TurboTeG4)
You can reuse that thing no problem. Ideally, you would want to replace it--but Cometics are quite expensive--I think I use to pay $80 for 79mm 0.030" d16 HG.
Old Nov 26, 2006 | 04:09 PM
djnikko's Avatar
Default Re: (d16dcoe45)
Ive spoke to my engine builder and he is happy to reuse it. I'd prefer to go with the reused cometic than the brand new motor factors gasket. Im just trying to save soem money really but trying to also make sure I dont get bitten in the *** later down the line.
Old Nov 26, 2006 | 04:26 PM
dude_123's Avatar
You can reuse the headgasket if the sealer "black stuff" on the gasket did not stick onto the block or head. The headgasket is made to seal when the engine heats up melting the sealer to bond the gasket to the head and block.
Old Nov 26, 2006 | 04:54 PM
djnikko's Avatar
Default Re: (dude_123)
Nice one thanks for that
I'll be sure to check if it hasn't sealed. Its been sat in a cold workshop so it may turn out all good
Kris's turbo
Jun 6, 2008 07:40 PM
FunIntegras
Nov 22, 2005 06:16 AM
Wide Open Throttle
Feb 25, 2004 07:27 PM
Vero
10
Jan 28, 2004 02:20 PM
BoostedB20A
May 11, 2003 03:12 PM
