help with aftermarket stereo
Old Nov 16, 2006 | 09:50 PM
premier_ek9's Avatar
Default help with aftermarket stereo
i bought a kenwood cd player form my friend and the wires arent labeled, wat does the yellow wire, red, blue and purple with a stripe go to? any help please!!!
Old Nov 16, 2006 | 10:22 PM
wudini's Avatar
Default Re: help with aftermarket stereo (premier_ek9)
red is 12v
yellow is 5v constant
pretty sure blue is power antenna wire/usually used as amp power
and i thought purple was a speaker color. there should be a purple and a purple with a stripe.
Old Nov 16, 2006 | 10:27 PM
Default Re: help with aftermarket stereo (wudini)
there is a purple with a stripe and a purple, but there is a blue and a blue with a stripe
Old Nov 16, 2006 | 11:26 PM
sasser43's Avatar
why didnt you just get a harness?
purple and purple stripe will be the hookup for one speaker, and the blues for another. if no one on here can tell you, your best bet probably is to uncover the speakers and see which wires are going to it.
Old Nov 16, 2006 | 11:48 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: help with aftermarket stereo (sasser43)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by premier_ek9 &raquo;</TD></TR><TR><TD CLASS="quote">there is a purple with a stripe and a purple, but there is a blue and a blue with a stripe</TD></TR></TABLE>
gray and white wires are the front speakers (left and right)
green and purple wires are the rear speakers (left and right)
yellow is CONSTANT 12v (memory)
Red is switched 12v (ignition)
The blue and blue with stripe are both turn-on wires. One is for a power antenna, and the other is for amplifiers, although I can't remember which is which.
Old Nov 17, 2006 | 06:11 AM
92ehatch's Avatar
Default Re: help with aftermarket stereo (JDM_Ej)
go to best buy or circuit city, or walmart and get a harness for your car
then just match the colors. its easy. about $20
or, go to circuit city and get a harness for your car, and a harness for your cd player and its all plug and play. cost about 35 - 40
Old Nov 17, 2006 | 06:21 AM
vestalfootball72
Guest
Posts: n/a
Default Re: help with aftermarket stereo (92ehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92ehatch &raquo;</TD></TR><TR><TD CLASS="quote">go to best buy or circuit city, or walmart and get a harness for your car
or, go to circuit city and get a harness for your car, and a harness for your cd player and its all plug and play. cost about 35 - 40</TD></TR></TABLE>
best bet is to get a harness
- kenwood isnt carried by circuit city anymore however, so your giong to have to color match them instead of using the smart harness
Old Nov 17, 2006 | 07:18 AM
RickyBizee's Avatar
Yeah your best bet is to get a harness at Circuit or BEstbuy it will all be color cordinated from there...unless your factory harness is already cut then you will have to hard wire it like your doing. Here is all you need to hook up if hardwiring
Yellow = Power
Red = Accecsory (allows radio to turn on in acc position plus the radio wont work with out it.)
Black = Ground
White and White/blk stripe = left front speaker (black stripe is negative)
Gray and Gray/blk stripe = Right front speaker (black stripe negative)
Green and Green/blk stripe = Left rear speaker (blk stripe negative)
Purple and Purple/blk stripe = Right rear speaker(blk stripe negative)
Solid Blue = Power Antenna (hook this up only if you have power antenna)
That is all you need for your radio to work properly any other wires just crimp the ends or e-tape them up so there is no exposed wire that could short out your radio. Most harnesses will come with solid blue (power antenna) and blue and white stripe (amp turn on) but I have seen some with only a solid blue , or only a blue white stripe, either way you can use either one for amp turn on or power antenna.
If you go to Bestbuy or Circuit city just tell them you need a wiring harness for your make model and year of your car. Thats the easy way cause then you dont have to go look up hondas wiring diagram to make sure you got the right wires hooked up, plus you dont cut into your factory harness. If you get the harness it should plug right up to your factory harness and then connect the wires by color.
Dont worry about hooking up orange wires, and stuff they are for other things that you dont need. Just etape the ends. Hope this helped.
p.s. you can also find harnesses for your car at autozone and walmart, but I woldnt reccomend those, as they are crap, and confusing because instead of comming with just the one for your car, it comes with multiple harnesses for diff hondas.
Old Nov 17, 2006 | 02:26 PM
Default Re: help with aftermarket stereo (RickyBizee)
the harness in the car has been cut so its all wires
standbackimapro
Audio / Security / Video
Sep 11, 2007 11:30 AM
tnm1303
Apr 7, 2006 03:53 AM
jdmaek
Jan 9, 2005 11:15 PM
BLUE EH3
Aug 25, 2004 04:39 PM
Full Race A6
Apr 4, 2004 07:12 AM
