JDM Rx Pedal in EK.
Old Nov 16, 2006 | 12:05 AM
GloomyX's Avatar
Default JDM Rx Pedal in EK.
I saw those Rx pedals last night, and i fell for them!!
But my question is, those Rx pedals are from CTR and DC2/5, and S2000 adopted them too. Of what I could find out, the S2000 verison will not work. But I can't come up with another for the CTR and DC2/5 verison.
Does anyone have these pedals? And how did you proceed to install them?
Old Nov 16, 2006 | 12:34 AM
BlueIntegraBoy's Avatar
Default Re: JDM Rx Pedal in EK. (GloomyX)
The clutch and gas pedals bolt up, and you need to rivet the brake pad onto your stock brake pedal. This is what I have read.
Old Nov 16, 2006 | 12:48 AM
Eran's Avatar
HT White Ops
As far as I was aware, you could just bolt them in....
Old Nov 16, 2006 | 04:10 AM
B16B_coupe's Avatar
HRD PKR
Default Re: JDM Rx Pedal in EK. (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">The clutch and gas pedals bolt up, and you need to rivet the brake pad onto your stock brake pedal. This is what I have read.</TD></TR></TABLE>
Old Nov 16, 2006 | 05:50 AM
6SPD_EK's Avatar
got 'em
I re-riveted the brake & clutch to original pedals...gas pedal was a bitch... cut arm & welded it to original arm... you might be able to swap whole gas pedal on but I think it will line up differently & not be even with other pedals
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">As far as I was aware, you could just bolt them in....</TD></TR></TABLE>
WRONG!!!!!
don't know about what all those guys ^ are talkin' about that don't even have 'em
this is for EK...those guys may have been thinkin' about eg/dc's *shrugs*
Old Nov 16, 2006 | 06:13 AM
sirsmokesalot's Avatar
just get the mugen pedals
Old Nov 16, 2006 | 07:04 AM
6SPD_EK's Avatar
Default Re: (SirSmokesAlot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SirSmokesAlot &raquo;</TD></TR><TR><TD CLASS="quote">just get the mugen pedals </TD></TR></TABLE>
type R/X &gt; moogen
Old Nov 16, 2006 | 07:09 AM
JDM_teh_WIN!!'s Avatar
Default Re: (_adirondackR_)
I thought you can buy the whole RX pedal assembly and swap those in????
Whole pedal assembly &gt; Just pedals
Old Nov 16, 2006 | 07:19 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: (JDM_teh_WIN!!)
those are hawt. Price?
Old Nov 16, 2006 | 07:21 AM
Default Re: (attentionwhore)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by attentionwhore &raquo;</TD></TR><TR><TD CLASS="quote">those are hawt. Price?</TD></TR></TABLE>
$140
Old Nov 16, 2006 | 07:26 AM
AztecGreenSi's Avatar
i bought the same pedals not long ago. I have yet to install them. I have an EG and was wondering if they will bolt in or will I have to rivet the brake as well?
Old Nov 16, 2006 | 07:33 AM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">I thought you can buy the whole RX pedal assembly and swap those in????
NO YOU CAN'T JUST SWAP IN!!!!!!! - I POSTED HOW DO IT... reriveting pedals to stock (usdm arms) takes 2 minutes... gas pedal is a bitch if you want the pedal in the stock location (level with other pedals)
I am not sure about eg
Old Nov 16, 2006 | 07:37 AM
Shouldnt they be the same between USDM and JDM? Did you remove the your USDM ones and try to put the JDM ones in? Just curious.
Old Nov 16, 2006 | 07:41 AM
6SPD_EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">Shouldnt they be the same between USDM and JDM? Did you remove the your USDM ones and try to put the JDM ones in? Just curious.</TD></TR></TABLE>
JESUS CHRIST.... no they are NOT the ******* same,
<FONT SIZE="6">THEY ARE NOT THE SAME & DON'T SWAP IN - YES I TRIED, YES I HAVE THEM IN MY CAR, I KNOW 100%
LHD DOES NOT EQUAL RHD </FONT>
*shakes head*
Old Nov 16, 2006 | 07:45 AM
LOL. Ok settle down.
Old Nov 16, 2006 | 07:58 AM
6SPD_EK's Avatar
reviting the pedals to the arms is easier than installing the whole arm assemblies - anyways
as I said gas pedal can be a bitch if you want it done right - because of the Left to Right angle as well as the angle/pitch that it sticks out... I believe one of the gas pedals (usdm or R/X) had a different thickness/depth to the part that hits the floor... so in other words the pedal would hit the floor, instead of being 100% WOT it would be like 95% WOT...check it out - maybe I am full of ****
Old Nov 16, 2006 | 08:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _adirondackR_ &raquo;</TD></TR><TR><TD CLASS="quote">reviting the pedals to the arms is easier than installing the whole arm assemblies - anyways
P </TD></TR></TABLE>
So wouldnt it be fair to say then that the easiest way to do this would be to simply rivet all the pedals to your existing arms?? My only problem with this would be the size of the gas pedal as the Rx one is tiny in comparison to the OEM pedal on my EG
Old Nov 16, 2006 | 08:21 AM
6SPD_EK's Avatar
Default Re: (AztecGreenSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AztecGreenSi &raquo;</TD></TR><TR><TD CLASS="quote">
So wouldnt it be fair to say then that the easiest way to do this would be to simply rivet all the pedals to your existing arms?? My only problem with this would be the size of the gas pedal as the Rx one is tiny in comparison to the OEM pedal on my EG</TD></TR></TABLE>
yes... BUT the gas pedal is not riveted on... its welded to the arm... so really no
clutch & brake - rerivet in less than 5 minutes... gas pedal = t3h b1tcH
Old Nov 16, 2006 | 08:23 AM
yes... BUT the gas pedal is not riveted on... its welded to the arm... so really no </TD></TR></TABLE>
Okay, so I'll rivet the brake and clutch pedals and cut and weld the gas pedal. I'm just rying to figure out the simpliest way to do this.
When you welded your gas pedal...did you just simply remove it and cut and weld?
Old Nov 16, 2006 | 08:30 AM
6SPD_EK's Avatar
When you welded your gas pedal...did you just simply remove it and cut and weld?</TD></TR></TABLE>
yes but then we realized it was at the wrong pitch... in other words we cut both pedal arms (on the upper half of the arm) in the same place at what appeared to be the same angle - but b/c arms angles were different below the cut (angle of a bend) - we had to recut & reweld.
make sure you look at the back of the pedal usdm compare to R/X too - I think the r/x has a deeper base that will hit the floor (before 100% wot) if you bolt just the whole r/x assembly on
Old Nov 16, 2006 | 08:34 AM
make sure you look at the back of the pedal usdm compare to R/X too - I think the r/x has a deeper base that will hit the floor </TD></TR></TABLE>
Okay, thanks for the advice. I'm probably not going to attempt this myself and I don't have any experience with welding. I'll take it to a local shop and see if they can make something of it.
Old Nov 16, 2006 | 08:46 AM
6SPD_EK's Avatar
make sure you look at the back of the pedal usdm compare to R/X too - I think the r/x has a deeper base that will hit the floor (before 100% wot) if you bolt just the whole r/x assembly on </TD></TR></TABLE>
to help with that verbal ^ explantion
see
Old Nov 16, 2006 | 10:08 AM
awesome, thanks for the visual.
NathanMorris
Apr 10, 2015 12:43 PM
wrinkly
Oct 5, 2009 07:50 AM
logikbmb
Honda Civic (2001 - 2005)
Oct 5, 2007 01:43 PM
egekreject
Sep 13, 2007 04:03 PM
PY 01-0972
Oct 29, 2004 03:37 PM
