Integra Type Rx pedal set question
I might have the opportunity to pick up a set of Type Rx pedals. I was just wondering how difficult it would be to install on a LHD car.
I know that the brake pedal pad needs to be riveted on but apparently the brake and gas pedals are bolt on and consist of the entire arm and pedal assembly. My question is will these two be bolt up and go or would i have to go about adjusting the clutch position etc?
Thanks
Thanks
#1 Super Guy
Re: Integra Type Rx pedal set question
It's the brake pedal arm that has a completely different bend in it due to the RHD steering colum following a different path...
From the look, the clutch and throttle will bolt up fine. I did a lot of research on this years ago, but now I'm not 100% though...
My set took about 40 minutes to install and they were a direct bolt up. The brake pedal pad is just three rivets. The most difficult part was trying to work under the dash with the pedal springs and not get a cramp in my back.
This is a bad pic but its the only one I could find. If you need later I can take a closer pic of the pedals installed if it helps you out.
is there a special tool i need to rivet the brake pedal pad in?
thanks everyone for their help, it's greatly appreciated!
#1 Super Guy
from my research, both the clutch and gas pedal assemblies are direct bolt on (ie: you swap the entire arm with the USDM one). it is just the brake pedal pad that has to be riveted onto the stock USDM arm
the gas pedal will delete ur cruise control. i just cut off the base of my stock pedal and welded in the new one . since it was slightly longer then my stock one
ON TOPIC: looks like a cool mod, debating that or Mugen pedals.
The Cruise control in Our Type R's ? I may be speaking for all type r owners, but my cruise control is planting my heal on the tunnel and keeping my foot in the same place on long road trips. stick to your red SI...idjit
ya but i still plan on retrofitting cruise control into my itr. :p
well, then here is a "how to" for ya.. old school style..
http://www.sandmracing.com/
go to upgrades and mods, OEM Cruise control...
well it looks like you dont speak for everyone . maybe you should keep your negative attitude to yourself . im just contributing to the topic in a thread like forums are meant to be used .
I have actually already contributed more to this post as I piggybacked on your comment (which does not apply to 100% of Type R's given NONE had cruise from the factory), and BlackR's comment on wanting to install Cruise in his, so I posted a link to a full How To Install Cruise in an R.
And then a link to some Cheap Mugen Pedals for the OP
who cares, this is the R Forum, not the " Multiple Car Forum"
Idjit.
SlapSmak too bad i already ordered the Rx pedals....if you would have linked me to the mugen auction earlier i would have probably jumped on those...thanks for the help tho.
Don't judge or question
Mugen set on ebay right now for 65$:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
NP, bought a set for myself...might sell em, might install em.
When you get the Rx pedals, take some pics when you do the install for a DIY...
yea once they come in I'll try to snap some pictures and post the DIY....hopefully in the next couple of weeks
No offense, but you know this how? they look exactly the same, same surfacing, same gas pedal, same box as I have seen on other sites.
i just took a look on the king website...and the ones on ebay do look very similar/if not exactly like the ones advertised by king...
then again, the chinese fake market has products that are almost exactly the same real ones.
That is correct. Sorry the brake does have to be rivited on. As far as for cruise control, I drive a 98 so I can't really give you advice on that.
