b16 with sc34
my first ever turbo setup looking to make 300-350whp on stock motor.
b16
lsd tranny
sc34 turbo .60 .63
ramhorn manifold
tial 38mm wastegate
2.5in piping
3in dp & exhaust
680cc injectors
255 intank fuel pump
greddy type s bov
thinkings of getting thicker headgasket, and headstuds
going to be tuned on Crome. how much psi should i run to achieve this goal? i was thinking of running 12psi this is my DD. the motor is in a Delsol chasis.
here some pics. (camera phone)
i got couple more pics. just need to email them to myself
b16
lsd tranny
sc34 turbo .60 .63
ramhorn manifold
tial 38mm wastegate
2.5in piping
3in dp & exhaust
680cc injectors
greddy type s bov
do you have B16 a or b. Headstuds and thicker headgasket won't hurt, cheap investment. Check C-speedracing.com to get a compression check. Your set-up is fine, I would look into an oil catch can if u do not have one, something like Endyn look up(theoldone.com) FPR can help too. Along with some cam gears. All cheap parts that can give you more power and durability. Exact boost psi I cannot tell it will depend on how your parts work together. On that turbo I will guess between 14-18psi to reach 350whp.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecCarHauler »</TD></TR><TR><TD CLASS="quote">do you have B16 a or b. Headstuds and thicker headgasket won't hurt, cheap investment. Check C-speedracing.com to get a compression check. Your set-up is fine, I would look into an oil catch can if u do not have one, something like Endyn look up(theoldone.com) FPR can help too. Along with some cam gears. All cheap parts that can give you more power and durability. Exact boost psi I cannot tell it will depend on how your parts work together. On that turbo I will guess between 14-18psi to reach 350whp.
thanks for your input. whats your setup?
i have a BONE STOCK b16 motor.
anymore opinions?
anymore opinions?
yeah I forgot the cams, GSR or ITR's. I have seen the dyno graphs numerous times. The GSR's make at least 25-45whp over oem B16's. Checkout evans-tunning.com and study the dynographs. That is what I do when I am building a new setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IceySC »</TD></TR><TR><TD CLASS="quote">is that a peakboost manifold? nice</TD></TR></TABLE>
no i dont think so. i think its just a regular ramhorn
DubyaAye
Apr 17, 2004 09:03 AM
