a USDM B16A2 HEAD on a JDM B16A1 block with JDM B16A1 internal?
Old Nov 14, 2006 | 05:23 PM
Nameless Warrior's Avatar
Default a USDM B16A2 HEAD on a JDM B16A1 block with JDM B16A1 internal?
Now, I want to swap out the complete JDM B16A1 head and replace it with a USDM B16A2 head for smog emission purpose. I was wondering if I can just do that adn leave the block alone? Do I have to switch our the piston or anything?
Old Nov 14, 2006 | 05:36 PM
Default Re: a USDM B16A2 HEAD on a JDM B16A1 block with JDM B16A1 internal? (Nameless Warrior)
bump!
Old Nov 14, 2006 | 05:40 PM
lightcrx's Avatar
heads are the same just change the intake mani....
Old Nov 14, 2006 | 05:54 PM
Default Re: (lightcrx)
more details please!
Old Nov 14, 2006 | 05:57 PM
Eran's Avatar
HT White Ops
There's no JDM B16A1. Just a B16A.
Old Nov 14, 2006 | 10:22 PM
quicksilver1689's Avatar
i ♥ snails
owned
Old Nov 14, 2006 | 10:40 PM
spork motorsports's Avatar
* B A N N E D *
Default Re: (quicksilver1689)
whats a b16a1? are you sure you didnt get scammed and get a d16a1 with the d converted to a b?
Old Nov 14, 2006 | 11:11 PM
Eran's Avatar
HT White Ops
Default Re: (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">whats a b16a1? are you sure you didnt get scammed and get a d16a1 with the d converted to a b? </TD></TR></TABLE>
A B16A1 would be a 1st gen B16A with cable transmission from europe.
Old Nov 15, 2006 | 12:53 AM
Default Re: (Eran)
Look guys,
I know my motor. Trust me. when I place the B16A1 is to inform you guy that it's the First gen B16A. I know the diff between my B16A and B16A2. I am not gonna go into detail about B16A and B16A SIR-2 becuase I am pretty sure you guy also kjnow about that. So you can take all that "OWNED" somewhere else. I am just asking question about the heads.
Old Nov 15, 2006 | 06:49 AM
JDM_teh_WIN!!'s Avatar
Default Re: (Nameless Warrior)
Nothing about the heads are different except maybe the cams, unless all you are worried about is the markings on it from when it was produced. Just switch out the throttlebody and use a OBD2 dizzy.
Old Nov 15, 2006 | 09:49 AM
Default Re: (JDM_teh_WIN!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_teh_WIN!! &raquo;</TD></TR><TR><TD CLASS="quote">Nothing about the heads are different except maybe the cams, unless all you are worried about is the markings on it from when it was produced. Just switch out the throttlebody and use a OBD2 dizzy.</TD></TR></TABLE>
Great!! Finally an answer.
so, basically I can just switch out the throttle body and put on a OBD2B Dizzy and I'll be back to USDM spec? Tell me it's that EASY PLEASE!
Old Nov 15, 2006 | 09:55 AM
nighttrain33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">
so, basically I can just switch out the throttle body and put on a OBD2B Dizzy and I'll be back to USDM spec? Tell me it's that EASY PLEASE! </TD></TR></TABLE>
I don't want to thread jack, but for everyone's knowledge, where does the extra compression come from in the SIR II? It wouldn't make sense for the only differences to be the TB and dizzy. Unless whatever is different between the a and the a2 to cause the comp. difference won't effect emissions.
-Shane
Old Nov 15, 2006 | 10:44 AM
Default Re: (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">
-Shane</TD></TR></TABLE>
I would also like to know.
Old Nov 15, 2006 | 12:39 PM
Its like 10.4 (B16A) vs 10.2 (B16A2). Also someone mentioned using a B16A2 intake manifold not sure if that matters but it might.
Old Nov 15, 2006 | 05:26 PM
lightcrx's Avatar
it does matter use a usdm a2 manifold.... look at a first gen b16 mani and then a a2 mani you'll see theres alot of differances, .2 in compression wont matter for sniffer
Unseen Racer
Apr 13, 2009 09:33 AM
S1_DJai
Oct 30, 2005 11:05 PM
spidermancivic
Apr 10, 2005 05:40 PM
poetter
12
Feb 24, 2005 10:46 AM
EVOCELICA
May 22, 2002 09:36 AM
