Need some wide band help
https://honda-tech.com/zerothread?id=1810155 i fugured i would post in hee there is just a little more action in here..
thanks for the help
thanks for the help
thanks for the link but do i need my stock narrowband sensor in? or should i tap wires into the wide band from the narrow band wiring to make the computer think it is still reading the stock o2 so it doesnt throw a CEL? im kind of stumped
i tried wiring my aem in to replace the oem... even called aem tech support on it. it never did work out for me. i finally just welded a bung into the downpipe for the wideband
I'm unsure about AEM, but with uberdata and crome i believe you can select what o2 sensor you are running. You have to disable the o2 heater, and then wire in the narrowband signal. D14 i believe for the d-series. Not sure though. I've done it before, but i just use a second bung and that way i can pull it out and tune my friends cars for them.
WildPig
Jun 4, 2005 11:30 AM
