how do check the map sensor on crx
Old Nov 13, 2006 | 09:23 PM
h22_crx's Avatar
Default how do check the map sensor on crx
Old Nov 13, 2006 | 09:33 PM
Coltmorris's Avatar
Default Re: how do check the map sensor on crx (h22_crx)
Yea i dunno--i was having thoughts about my map but since im not throwing a code, nor can i replace it with a known good one as of now, i assume its fine. Is there such an instance where the MAP was bad but did not throw the cel? or would the motor just go into limp mode
Old Nov 13, 2006 | 09:39 PM
mikey mike's Avatar
change it out or use a meter and check for 5v power and ground, then check for signal between the map sensor plug and the ecu pin c11
Old Nov 13, 2006 | 09:48 PM
h22_crx's Avatar
Default Re: how do check the map sensor on crx (mikey mike)
whaT SHOULD it be
Old Nov 13, 2006 | 10:15 PM
Max Kling's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikey mike &raquo;</TD></TR><TR><TD CLASS="quote">change it out or use a meter and check for 5v power and ground, then check for signal between the map sensor plug and the ecu pin c11</TD></TR></TABLE>
Pretty much what he said, heres a break down from the honda manual.
Black lead of multimeter on the GRN/WHT and red lead on YEL/RED with the igniton switched on and see if you get 5V. If not, damn that sucks, tell us and Ill try and help you with some wiring.
If there is 5V, get the multimeter back out and put the red lead on WHT and black lead on GRN/WHT and see if you also get 5V. Once again tell us and I can help you out a little more.
If there is 5V reconnect the 3 prong back to the map and get the multimeter back out and get access to the ECU. Put red lead to C11 and black lead to C14 and see if you get 3V while the ignition is on. If all of this is good then the map sensor is bad.
Old Dec 2, 2006 | 09:07 AM
Creator's Avatar
Default Re: how do check the map sensor on crx (Max Kling)
good info I'm having a problem with my MAP as well thxs for the inadvertent help.
cleanazcoupe
Engine Management and Tuning
Jul 8, 2009 09:28 PM
§95HATCH§
Apr 6, 2009 12:40 PM
kenfu
Sep 16, 2008 04:15 PM
liftdhatch95
Dec 24, 2007 12:17 PM
sleepin91teg
Aug 5, 2004 04:39 AM
