how do i install ctr wing ?
Old Nov 13, 2006 | 05:39 PM
Pnoyej6's Avatar
* B A N N E D *
Default how do i install ctr wing ?
Modified by PnoyEj6 at 10:21 PM 11/13/2006
Old Nov 13, 2006 | 05:45 PM
Ricey McRicerton's Avatar
Default Re: how do i install ctr wing ? (PnoyEj6)
Just how to remove the old one or how to wire the new one?
Old Nov 13, 2006 | 05:58 PM
jdmB18CT-R's Avatar
Default Re: how do i install ctr wing ? (Ricey McRicerton)
Old Nov 13, 2006 | 05:59 PM
Pnoyej6's Avatar
* B A N N E D *
how to remove old one? and rewire the new one. I know dumb question
Old Nov 13, 2006 | 06:09 PM
Bense's Avatar
without trying to be a jerk, but I really think that if you went out to your car and looked it would take less time than creating this thread.
grood luck
grood = Great + Good
Old Nov 13, 2006 | 07:48 PM
Default Re: how do i install ctr wing ? (Bense)
To get the old one off, there are 2 exposed bolts. You have to pull off the little plastic cover to see the 2 other bolts that aren't exposed. There is also a little plug you have to pinch in the center of the wing so that when you pull it upwards, it slips out. Disconnecting the hose for the windshield washer and disconnecting the connector for the brake light should be pretty self explanitory.
You're on your own as far as re-wiring the new brake light. I haven't done that before.
Old Nov 13, 2006 | 09:05 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">
You're on your own as far as re-wiring the new brake light. I haven't done that before.</TD></TR></TABLE>
CTR wing doesn't have a 3rd brake light
Old Nov 13, 2006 | 11:49 PM
ridetrials's Avatar
Default Re: how do i install ctr wing ? (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
CTR wing doesn't have a 3rd brake light</TD></TR></TABLE>
correct
Iloveyourhonda92
10
Nov 8, 2010 07:10 PM
GetSmoked
30
Mar 12, 2005 01:02 AM
2K2S2K
Sep 20, 2004 09:26 AM
jdm5ghb
44
Aug 6, 2003 03:00 PM
hothatch
Jun 28, 2001 01:18 AM
