88hf crx d16y8 idle jump IACV- video
Old Nov 13, 2006 | 03:54 PM
6doorsentra's Avatar
Default 88hf crx d16y8 idle jump IACV- video
88crx hf crx. no vacumm leaks, just jumping idle..obd2 d16y8 so there isn't any fitv...only IAVC on the back of the manifold. Mine is in clean condition, i dont see how this can be the problem..especially if the screen is clean..?
heres a link
http://ca.video.yahoo.com/vide...94089
Old Nov 13, 2006 | 06:09 PM
NikoZai's Avatar
Default Re: 88hf crx d16y8 idle jump IACV- video (6doorsentra)
maybe ummm replace it
I cleaned the **** outa mine too. Still does it until it's warm. Got one from the junkyard for $5.
Old Nov 13, 2006 | 06:32 PM
JUN.'s Avatar
Default Re: 88hf crx d16y8 idle jump IACV- video (NikoZai)
loool, mine does the same thing
Old Nov 18, 2006 | 03:07 PM
the idle screw is behind the map sensor on my throttle body i didn't know it was there..i adjusted it and it went to normal..problem solved..it WASNT the IACV
Old Nov 18, 2006 | 03:28 PM
91jdmcrx's Avatar
hey mine does it too im gonna try adjusting the idle screw too to see if it fixes the problem, hopefully it does.
Old Nov 18, 2006 | 05:03 PM
Boosted Chemist's Avatar
Default Re: 88hf crx d16y8 idle jump IACV- video (91jdmcrx)
ive heard that the obd1 iacv work better due to a bigger hole esp with obd1 ecus. (what ecu you running?)
Old Nov 18, 2006 | 05:16 PM
91jdmcrx's Avatar
Default Re: (6doorsentra)
I closed the screw a bit and it worked my idling doesn't jump no more thanks for the info
Old Nov 18, 2006 | 08:52 PM
Iron_Forrix's Avatar
on cold idle it ive noticed it can be fixed by adjusting the idle screw, but in some cases it only covers up the problems that may be caused by the iacv.
on my old engine (d16y7) it did that on cold star till warmed up. now my recently installed d16z6 has surging idle when warm. opposite temperature problem but both were due to the iacv. cleaning can help, but replacement is the best usually. Which is what i have to do with my z6
Old Nov 20, 2006 | 02:05 PM
REMEMBER MY motor is a d16y8, which obd2 not your z6 or whatever.. My IACV is like in new/perfect condition its common sense it wouldn't be it..I rather check down the list to make sure i knocked everything out cheaper/smaller if possible before i spent some money into it. 99 d16y8 with p28
They all serve the same purpose, your not getting preformance out of your IACV so whateever you heard about bigger hole and ecus...is just "he say" she say" ****..
use the proper one for your intake manifold and wire it up correctly..you'll be fine
Old Nov 20, 2006 | 08:26 PM
Crx505's Avatar
Default 85 crx
i was wonderin what kinda of motor swap u think i can pull wit my 85 crx i need help and i wanna find some lunar lights for it well if u know somethin just message me or somethin i would really appriciate it thanks POLO
djandy
14
Aug 28, 2014 10:10 AM
99GreenEX
Nov 29, 2007 07:52 PM
ITLNstallion818
Aug 11, 2007 08:35 PM
methyd
May 13, 2004 02:36 PM
