b18b in ek coup question
Old Nov 12, 2006 | 06:35 PM
Ha Itz's Avatar
Default b18b in ek coup question
im putting in a obd2 ls in my ek coupe and i was woundering if i can use my stock mounts or the ls mounts and my stock wiring harness... also can i use the ls rear bracket or do i need the si 99-00 rear bracket
Old Nov 12, 2006 | 06:58 PM
93lsd's Avatar
your gonna have to use all 99-00 civic si engine mounts even the rear bracket deff, and as for the engine harness what model do you have, but if you want a direct wire up use also a civic si and not use the vtec wires and in the near future you might wanna go ls/vetc then you are ready
Old Nov 12, 2006 | 07:08 PM
Ha Itz's Avatar
Default Re: (93lsd)
its a dx.. so i cant use the ls wiring harness or my stock one?
Old Nov 12, 2006 | 07:33 PM
93lsd's Avatar
you should be able to use a ex harness and just extend some wires, and youo should be fine
Old Nov 12, 2006 | 07:37 PM
Ha Itz's Avatar
Default Re: (93lsd)
ok but i couldnt use the ls rear bracket? and wat eles do i need.. i have the motor tranny axles, shift linkaage, ecu, starter and thats it
Old Nov 12, 2006 | 09:15 PM
93lsd's Avatar
no the ls will not woork i believe it is little longer
Old Nov 14, 2006 | 05:28 PM
blackeg's Avatar
Default Re: (93lsd)
you can use the stock dx harness, i think the only sensor you will have to extend is the purge valve solenoid. and the crank fluctiation sensor thing on the oil pump doesnt directly wire up.
99-00 si or 94+ integra shift linkage, 99 si T bracket and drivers side bracket (the one that bolts directly to the block behind the timing belt cover. the rest of the mounts are from your dx
EFdood831
Aug 17, 2009 07:27 PM
ar3dd
Nov 24, 2006 03:56 PM
1995hatchcx
Apr 20, 2004 11:12 PM
EjadomaK
Jul 4, 2003 08:10 PM
Midwestrider
Oct 29, 2002 04:12 AM
