Stock ECU + Turbo questions
Old May 7, 2002 | 06:49 PM
Ramocheese's Avatar
Default Stock ECU + Turbo questions
Hey everyone, I had a couple questions regarding what I should do.
I was thinking about buying an fmax turbo kit, but without the additional injector BS they include with it. Instead, I was going to run a S-AFC, a set of DSM 450cc injectors, and one of those wideband O2 kits you put together yourself for tuning with the typical EGT gauge. I am eventually going to go Hondata or AEM standalone, but until then, can I get by with the stock ECU on 8psi, or is it out of the question?
This is the first Honda I have owned. Previously I have owned a DSM for 3 years, and have gotten to the point where I can tune one blindfolded. I figure the same concepts apply with the Honda, although I don't know exactly how the stock ECU likes to respond.
Can I get by with stock timing on a stock headgasket? Or will I need to run something like the MSD boost retard? Also, what should I run to increase fuel pressure per pound of boost?
Thanks
[Modified by Ramocheese, 8:49 PM 5/7/2002]
Old May 7, 2002 | 07:11 PM
dubster99's Avatar
Default Re: Stock ECU + Turbo questions (Ramocheese)
Stock ECU doesnt like boost, you'll need to run a missing link bypass valve so that the ecu doesnt see the boost. You can run an FMU to take care of the fuel, but like you said standalone is the way to go. Tuning the fuel and timing will have to be done on a wideband o2, every car is different. Try the FI forum, I'm sure they can help you a lot more than I can.
Old May 7, 2002 | 07:14 PM
Erik_Pb_Foot's Avatar
New User
Default Re: Stock ECU + Turbo questions (dubster99)
get the missing link as a temp fix. just make sure you have fuel. forget fmax, go with revhard or drag.... no sense in paying the big dough for the fmax if you aren't even gonna use their fuel system (Which is the whole reason it's more expensive).
-Erik
Old May 7, 2002 | 07:15 PM
dubster99's Avatar
Default Re: Stock ECU + Turbo questions (Pb_Foot)
Yeah I haven't heard good things about Fmax either....I'd stay away from them.
Old May 7, 2002 | 07:47 PM
threatcon13's Avatar
New User
FORCED induction forum. AEM EMS owns hondata.
Old May 7, 2002 | 10:21 PM
SIK IN DA HED's Avatar
New User
dont get fmax.
you plan on using the safc and 450cc hack? you can adjust your settings -40. i would just get a drag or revhard kit. use the fmu and inline fuel setup til you can get yourself a hondata or whateva.
Rip Rawr
Nov 17, 2011 03:44 AM
SpoonMotorSport
Engine Management and Tuning
Aug 1, 2011 06:19 PM
Arch-Angel
Sep 17, 2003 06:41 PM
Ramocheese
May 7, 2002 08:59 PM
11secdx
Jan 6, 2002 11:32 AM
