slave cylinder help (ASAP)
Old Nov 12, 2006 | 04:54 PM
SOLvtec's Avatar
Default slave cylinder help (ASAP)
doing a b series swap in my del sol
had a d16z6 in it
the slave cylinder doesnt seem to match up to the b16 trans
i searched and i found d and b series slave cylinders are all the same
do i have to flip it around or somthing?
it seems way too high
Old Nov 12, 2006 | 06:20 PM
EG2Driver's Avatar
Default Re: slave cylinder help (SOLvtec)
is your shift fork bent or misplaced?
Old Nov 13, 2006 | 02:39 AM
SOLvtec's Avatar
Default Re: slave cylinder help (DeadEnd9009)
no, it seems to be ok
Old Nov 13, 2006 | 09:54 AM
SOLvtec's Avatar
bump
need some help
thanks
Old Nov 13, 2006 | 12:19 PM
EG2Driver's Avatar
Default Re: (SOLvtec)
take a picture so that i can see what you are talking about
Old Nov 13, 2006 | 12:26 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeadEnd9009 &raquo;</TD></TR><TR><TD CLASS="quote">is your shift fork bent or misplaced?</TD></TR></TABLE>
clutch fork and shift fork are completely different.
the hardlines are different, you have to "bend them" to get the D slave cylinder in place.
Old Nov 13, 2006 | 04:28 PM
SOLvtec's Avatar
Default Re: slave cylinder help (Bense)
do you have to flip the slave clyinder around
cus when i put the slave cylinder to the holes,
it is too high to push my release fork
thanks for the help
Old Nov 13, 2006 | 04:41 PM
dem0nk1d's Avatar
make sure the ball end of the push rod goes to the release fork.... you should be fine, also do you have it bolted correctly.
Old Nov 13, 2006 | 04:42 PM
SOLvtec's Avatar
Default Re: (dem0nk1d)
yeah, when i put it up to the holes, it just looked really high
Old Nov 13, 2006 | 05:20 PM
drtysohc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense &raquo;</TD></TR><TR><TD CLASS="quote">clutch fork and shift fork are completely different.
the hardlines are different, you have to "bend them" to get the D slave cylinder in place.</TD></TR></TABLE> you beat me to it haha.
Old Nov 13, 2006 | 06:49 PM
clm's Avatar
clm
You might just need to compress the push rod into the slave cylinder to get the mounting holes to line up.
Stillo
Oct 24, 2007 04:57 PM
GSRWSU
Oct 22, 2006 11:03 AM
mike1114
Jul 10, 2004 06:37 PM
93H22A
Apr 9, 2004 10:46 PM
