Need Help with weird problem on a sohc
Old Nov 12, 2006 | 06:46 AM
blue00sifun's Avatar
Default Need Help with weird problem on a sohc
1995 honda civic dx. Vehicle was stolen and then recoved (ignition switch was ok, just taken off the column, which I used tie wraps to reattach to column). After it was recovered, every few days when I go to start the car, when i crank the ignition to iii all i hear is a click coming from somewhere under the dash (does not sound like the starter). If i disconnect the negative from the battery and then reconnect, the car starts fine again for a few days until it does the same click, then I have to repeat taking off the negative from the battery....Can anyone guide me towards the right direction?
TIA!!!
Old Nov 12, 2006 | 10:35 AM
Default Re: Need Help with weird problem on a sohc (blue00sifun)
bump
Old Nov 12, 2006 | 04:16 PM
JDMFantasy2k's Avatar
bad negative ground cable? check for voltage drop.
Pagoda
Sep 15, 2014 09:30 PM
memo9259
Apr 7, 2014 10:50 PM
garysoldcars
Apr 4, 2008 01:46 PM
SILVA
Jan 24, 2008 06:09 PM
blue00sifun
Nov 25, 2006 11:06 PM
