Type-R pressure plate better than LS? (take 2)
Old Nov 11, 2006 | 06:44 PM
EJgsr's Avatar
Default Type-R pressure plate better than LS? (take 2)
i have a b18b and i have a type-r pressure plate laying around and was wodndering if the type-r has better clamping force.
thanks
Ps: its take 2 because i asked this before and no one could answer my question.
Old Nov 11, 2006 | 06:57 PM
EJgsr's Avatar
Default Re: Type-R pressure plate better than LS? (USDMej1)
come on people i know you know.
Old Nov 11, 2006 | 07:26 PM
pdiggitydogg's Avatar
maybe you should wait more than 15mins at a time for someone to answer your question?
itr is no different than other integra
Old Nov 12, 2006 | 07:24 PM
EJgsr's Avatar
Default Re: (pdiggitydogg)
can any one else tell me anything about this???
Old Nov 12, 2006 | 07:47 PM
NJcoupe's Avatar
Well considering they're different part numbers, I'd assume somethings different.
Old Nov 12, 2006 | 08:04 PM
EJgsr's Avatar
Default Re: Type-R pressure plate better than LS? (dxcoupe.)
i know the number are not the same but anyone with first hand experince???
Old Nov 12, 2006 | 09:31 PM
sheekdude's Avatar
The type r pressure plate is a couple of pounds lighter than any stock honda pressure plate. The type r one is between 15 and 17lbs which gives you more torque than the rest.
Old Nov 12, 2006 | 09:54 PM
Jimmy's Avatar
Global Moderator
The type r has more clamping force.. Not sure that's it going to be much, due to the fact that it's still an OEM pressure plate.. It will be better then the LS anyway
Old Nov 14, 2006 | 07:58 PM
EJgsr's Avatar
Default Re: Type-R pressure plate better than LS? (sheekdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sheekdude &raquo;</TD></TR><TR><TD CLASS="quote">The type r pressure plate is a couple of pounds lighter than any stock honda pressure plate. The type r one is between 15 and 17lbs which gives you more torque than the rest.</TD></TR></TABLE>
your wrong... they are the same weight. i have both sitting next to me. they are the same weight.
Old Nov 14, 2006 | 08:37 PM
slodel's Avatar
then why you asking dipshit
Old Nov 14, 2006 | 09:22 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Type-R pressure plate better than LS? (slodel)
The driveshaft on an ITR transmission is thicker, and a larger pilot bearing is used in the flywheel. This is the ONLY difference.
Old Nov 15, 2006 | 06:55 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 &raquo;</TD></TR><TR><TD CLASS="quote">i know the number are not the same but anyone with first hand experince???</TD></TR></TABLE>
I'm not trying to be an *** here, but what answer are you looking for?
None of us are mechanical engineers who can tell you the exact clamping force numbers in lbs., and again I can't even think of where to find the actual clamping force ratings for stock Honda clutches.
I would try asking an employee of a clutch company, such as ACT, Exedy, etc. I mean they rate their own aftermarket cluthces at "xx% more clamping force than stock clutch" so you'd have to think they would need to know the raw data for the stockers before claming a % above them, right?
I believe there is a member by the name of "ACT man" or something like that around H-T.
Old Nov 15, 2006 | 11:23 AM
EJgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slodel &raquo;</TD></TR><TR><TD CLASS="quote">then why you asking dipshit</TD></TR></TABLE>
i asked the question before i took apart my car.
i took it apart and weighed them.
i was just telling you guys...
sorry for telling.
flammer
Old Nov 15, 2006 | 12:16 PM
spork motorsports's Avatar
* B A N N E D *
seeing as tho you SHOULD replace the pressure plate when you do a clutch job, and you dont want to put a used clutch on a motor your building..................why would you give a expletive?
Old Nov 15, 2006 | 07:58 PM
EJgsr's Avatar
Default Re: Type-R pressure plate better than LS? (spork motorsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spork motorsports &raquo;</TD></TR><TR><TD CLASS="quote">seeing as tho you SHOULD replace the pressure plate when you do a clutch job, and you dont want to put a used clutch on a motor your building..................why would you give a expletive? </TD></TR></TABLE>
im a curious kid...
meeka661
Jun 21, 2014 10:20 AM
EJgsr
Oct 30, 2006 12:50 PM
BoOsTiN Dc2
Apr 2, 2006 02:29 PM
tegasaurus
Sep 22, 2003 11:55 AM
ericlee303
Nov 14, 2002 01:32 PM
