Idle problem
Old Nov 11, 2006 | 02:24 PM
Jdm_Eg686's Avatar
Default Idle problem
When i start my car up in the morning m idle is high for a couple of minutes and then it fluxuates between high and low. I already replaced my IACV and map sensor, from the local wrecking yard and is still messed up. Also i already checked for vacuum leaks and couldt find any... Any ideas? thanks
Old Nov 11, 2006 | 02:25 PM
POE's Avatar
POE
does is idle funny just when its cold?
or funny to when its at normal temp..
If its just cold its your FITV, underneith your TB. take the cap off the back of it and tighten the screw thing around the Ball (valve)..
The FITV has coolant running to it and tells the ecu witht he car is warmed up and how high to idle..
Hope this helps
Old Nov 11, 2006 | 02:38 PM
stealth50k's Avatar
Default Re: Idle problem (Jdm_Eg686)
Open up the iavc and theres a circle plastic thing inside that might not be screwed down all the way down. Just use a flat screw driver and turn the plastic clock wise to do it and it should go away. I use to have the same problem, it fixed it. I think theres a tutorial for this but i forgot the link.
Old Nov 12, 2006 | 12:43 AM
Jdm_Eg686's Avatar
Default Re: (POE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">does is idle funny just when its cold?
Hope this helps</TD></TR></TABLE> yes, it only does it when it is cold, are there any pictures of what the FITV looks like... thanks
Old Nov 12, 2006 | 12:44 AM
Jdm_Eg686's Avatar
Default Re: Idle problem (stealth50k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth50k &raquo;</TD></TR><TR><TD CLASS="quote">Open up the iavc and theres a circle plastic thing inside that might not be screwed down all the way down. Just use a flat screw driver and turn the plastic clock wise to do it and it should go away. I use to have the same problem, it fixed it. I think theres a tutorial for this but i forgot the link. </TD></TR></TABLE> ???? not sure what you are talking about
Old Nov 12, 2006 | 01:02 AM
carlosd68's Avatar
right under the throttlebody, theres a little water hose that connects to it
Old Nov 12, 2006 | 01:03 AM
carlosd68's Avatar
Default Re: Idle problem (carlosd68)
THIS IS WAT U NEED TO DO
https://honda-tech.com/zerothread?id=1564019
i clicked on search, typed in FITV
Old Nov 12, 2006 | 11:30 AM
Jdm_Eg686's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carlosd68 &raquo;</TD></TR><TR><TD CLASS="quote">THIS IS WAT U NEED TO DO
i clicked on search, typed in FITV </TD></TR></TABLE>
I should of done that before i whined like a BITCH, thanks man much appreciated.
decon
Dec 19, 2012 07:57 PM
joelmatt89
15
Nov 4, 2009 05:27 PM
rx_86
10
Dec 28, 2008 09:14 PM
jdmgeezer
Dec 9, 2007 11:23 PM
diLUDEd
Aug 22, 2002 10:08 PM
