96 civic odd problem
when trying to start the car it acts like the firing order is off or the timing is off well all has been checked and it is no everything is right. when it idles once it finally starts it sound ok till you try to give it gas seems to be getting to much gas and it is not trowing any trouble lights
please help
please help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axtran »</TD></TR><TR><TD CLASS="quote">you should check your timing. these questions are all the same after time...</TD></TR></TABLE>
he said in the original post that it was already checked....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 »</TD></TR><TR><TD CLASS="quote">hmm interesting idea i am sure thats why people ask questions on here to get your smart *** answers dumb ***</TD></TR></TABLE>
Your first post was a useless ramble of garbage, your second wasn't any better. I also didn't understand anything you tried to write in the PM you sent me either. If you can't type a sentence then you will have no idea how to communicate with someone on a computer to fix your car. So like I said, take your car to someone who knows what they are doing.
yeah like i said if you cant help dont answer people post on here for help, not to get smart *** answer from jack asses such as yourself.
now as i was saying i just changed the fuel filter as well althoughit seemed fine. is it possible the fuel pump may be weak and not able to keep up or maybe a ground i was told also ?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by davidcrx89 »</TD></TR><TR><TD CLASS="quote">yeah like i said if you cant help dont answer people post on here for help, not to get smart *** answer from jack asses such as yourself.
I may be a jackass but I speak english and my cars run, how about you? That's what I thought.
Learn english, make a post people can understand, and people will attempt to help.
If you think it is a fuel problem, your fuel pump might be on its way out. I think there is a way that you can take your fuel pump off and test it before you go and buy a new one. Also, make sure your fuel injectors are spraying properly and are clean.
Your injectors might be leaking when you shut the engine off, this will wash down the oil from the rings and you wont have compression to help with starting. Next cold start pull the plugs, put in a teaspoon of oil, crank engine to blow most oil out of cylinders, reinstall plugs, start car, let us know what happens. OH, let it run for awhile to blow the smoke out of its system, or just go around the neighborhood killing all the bugs. Are you getting black smoke on semi heavy accelleration now.
It could be a weak coil too but try above first, weak coil wont sound like timing is off, what I said above will.
ok so the car sat for 2 days i went out started it up to move it in to work on it and it seemed to run fine so i took it around the block it ran great then all the sudden it started stuttering and runing like hell again i timed it it is set perfectly at 16 degrees. so thats kinda wierd huh ??
How long was the car sitting for? That happpened to me a few times when the car had been sitting for a few days without being used. The usual maintenance took care of it, plugs, wires, dist cap & rotor, etc.
drummr6
Dec 15, 2005 10:18 PM
Jonovision
Sep 30, 2005 06:48 AM
