Greddy turbo kit install need help asap
Ok I just finished fixing a wiring disaster on a greddy turbo kit installed on my friends car. The kid who helped him install it said he needs no blow off valve??? Car flutters like crazy obviously because no BOV is installed. I told him thats retarded he need a bov to release the pressure that the flutter is bad. So i install a greddy rs he byes and cant get it to blow off. Tried every vacuum line in the car. I did get it to work by pulling the brake booster line of the manifold and using that to source the bov. It bolws of but the when I tee into original line it doesnt work. I am lost. I have worked on tons of turbo cars and never had this problem. Anyone have a clue whats up...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfsrt4 »</TD></TR><TR><TD CLASS="quote">Ok I just finished fixing a wiring disaster on a greddy turbo kit installed on my friends car. The kid who helped him install it said he needs no blow off valve??? Car flutters like crazy obviously because no BOV is installed. I told him thats retarded he need a bov to release the pressure that the flutter is bad. So i install a greddy rs he byes and cant get it to blow off. Tried every vacuum line in the car. I did get it to work by pulling the brake booster line of the manifold and using that to source the bov. It bolws of but the when I tee into original line it doesnt work. I am lost. I have worked on tons of turbo cars and never had this problem. Anyone have a clue whats up...</TD></TR></TABLE>
Having someone that ISN't a shop install a 3k kit on an 06 car = shouldn't happen
wiring all messed up? guess yall didn't get the memo the first time that the wiring in the istructions were reversed.
the kit doesn't come with a BOV and i don't think it's stated as needed in the instructions...many turbo cars don't run BOVs.
check and re-check all lines...
or do like my buddy and get ur money back ...
I have installed many kits that not the problem. You are correct though him and his buddy have not and messed up lots of stuff. I went threw everything and fixed it (yes including the reversed wiring). The car runs fine without a Bov just has a bad flutter when you get of gas. Which to me is from having no BOV. I told him to get one but cant seem to get it to work correct due to weak pressure lines or something. Greddy told me it was cool to run no bov but I would think after time the pressures going both ways threw the turbo would cause damage.
He did have a shop look at it after I went threw it and they said everything looked right. They showed him another place to tee into for the BOV source but once again it didnt work..
O well thanks guys for your input..
I did that. Like I said I pulled the line of the intake mani side and just put the bov directly to it and it worked great but then tried to tee it into original line and it wouldnt blow off. I didnt get it. I know the line to the bov was big enought maybe he had a cheap tee but dont see how it would loose that much pressure...
Correct! LOL.... what kind of problems your running into?
I have a BOV on mine and its vented 100% to the atmosphere. It just stalls out once in a while when I come to a complete stop. Besides that the car is running perfectly fine
TAKE IT TOO A SHOP???? I INSTALLED THE GREDDY KIT WITH NO PROBLEMS AT ALL, THAT KIT IS AN ALL BOLT ON SYSTEM! I MIGHT BE A NOOB BUT I CONSIDER IT COMMON SENSE... GREDDY IS THE ONE WHO FUCKED UP THE KIT, BY NOT INCLUDING THE BOV, AND MAKING THE INSTRUCTIONS BACKWARDS, AND HAVING A RECALL ON MOST OF THERE E-MANAGE ULTIMATE, YOU GO RIGHT AHEAD AND PAY PEOPLE TOO MAKE YOUR CAR FAST!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdave »</TD></TR><TR><TD CLASS="quote">TAKE IT TOO A SHOP???? I INSTALLED THE GREDDY KIT WITH NO PROBLEMS AT ALL, THAT KIT IS AN ALL BOLT ON SYSTEM! I MIGHT BE A NOOB BUT I CONSIDER IT COMMON SENSE... GREDDY IS THE ONE WHO FUCKED UP THE KIT, BY NOT INCLUDING THE BOV, AND MAKING THE INSTRUCTIONS BACKWARDS, AND HAVING A RECALL ON MOST OF THERE E-MANAGE ULTIMATE, YOU GO RIGHT AHEAD AND PAY PEOPLE TOO MAKE YOUR CAR FAST!
Umm you bought a greddy kit to make your car fast...
so your statement
YOU GO RIGHT AHEAD AND PAY PEOPLE TOOO MAKE YOUR CAR FAST...pertains to YOU too? Unless your some custom fabricator that created some super turbo system and fuel management....
</TD></TR></TABLE>Umm you bought a greddy kit to make your car fast...
so your statement
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Demonis »</TD></TR><TR><TD CLASS="quote">The greddy kit, from the sounds of the All Jap kit now, is a waste of money. </TD></TR></TABLE>
.... until the motor blows up from the AJP kit
no need to get too technical
if someone is going to say " take that 3k kit too a shop." then thats the person who dosn't have the ***** too do it themselves. It might be the greddy kit that i installed but either way, i install all my upgrades thats the only way i'm going to learn, if i mess up! oh well!
Probably obvious, but the only thing I could think of, is if you disassembled the BOV and checked to make sure the spring wasn't bound up and make sure there were no washers in the BOV to increase the spring tension... If you bought it new, it probably doesn't have any washers in there, but one thing to check out
Go talk to a shop. It could be worse...My kit is running alright but still a few little problems. The techs at cali greddy sent me the wrong basemap when I was updating my e-manage with the "new" basemap. Threw the car on a dyno and almost blew my motor because it was the wrong map. Detonation FTL!! Speaking of that Dan I talked to you the other day on the phone and I want to talk to you about cali greddy's f'up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdave »</TD></TR><TR><TD CLASS="quote">no need to get too technical
if someone is going to say " take that 3k kit too a shop." then thats the person who dosn't have the ***** too do it themselves. It might be the greddy kit that i installed but either way, i install all my upgrades thats the only way i'm going to learn, if i mess up! oh well! </TD></TR></TABLE>
it doesnt really apply to this thread, but i seem to see this alot and the university of memphis keeps beating **** in my head so here ya go...
too=also.... your statement= "take that 3k kit also a shop"
i just had to point out that t-o-o means also, not the same as t-o
if someone is going to say " take that 3k kit too a shop." then thats the person who dosn't have the ***** too do it themselves. It might be the greddy kit that i installed but either way, i install all my upgrades thats the only way i'm going to learn, if i mess up! oh well! </TD></TR></TABLE>it doesnt really apply to this thread, but i seem to see this alot and the university of memphis keeps beating **** in my head so here ya go...
ooohhh i'm sorry if i got that messed up! so very sorry! your the smartest one in this bunch! expletive you and i hope this thread gets blocked by the fuckass that runs this ****! expletive honda tech i'm out! erase my profile bitches, you will do me a favor! your the real noobs!
wow. i was just kidding. but alright. i can see that u have some issues with someone pointing out your flaws. u have a big total of 5 posts and u can NOT take a joke at all. people screw with each other on the internet. guess u never noticed that. good luck on a different board guy who cant take a joke
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigdave »</TD></TR><TR><TD CLASS="quote">ooohhh i'm sorry if i got that messed up! so very sorry! your the smartest one in this bunch! expletive you and i hope this thread gets blocked by the fuckass that runs this ****! expletive honda tech i'm out! erase my profile bitches, you will do me a favor! your the real noobs!</TD></TR></TABLE>
ok
bigdave is now banned from logging into this site. Click here to return to the administration interface.
ok
JustHere4ADay
Feb 3, 2005 09:40 AM
MikeExt
Nov 18, 2002 09:50 AM
