Suspension & Brakes Theory, alignment, spring rates....
Top Hat!
Old Nov 10, 2006 | 07:07 AM
94eg4's Avatar
Default Top Hat!
Who else make a top hat type upper strut mount besides Ground Control???
Thank You for your replies
Old Nov 10, 2006 | 09:45 AM
super_nguyen's Avatar
Default Re: Top Hat! (94eg4)
i believe PIC makes one, but im not sure if they sell them separately from their suspension, i have the ground control ones but you could even modify your stock top hats if you get someone to weld some pipe onto it.
Old Nov 11, 2006 | 11:40 AM
FalkenSiR's Avatar
Buy mine $20 bux shipped
Old Nov 11, 2006 | 11:52 AM
PIC Performance's Avatar
Default Re: Top Hat! (super_nguyen)
Yes ours are not sold seperately from the coilovers. Our extender upper mounts serve a different purpose than GC's as well.
Old Nov 11, 2006 | 02:41 PM
dvp's Avatar
dvp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super_nguyen &raquo;</TD></TR><TR><TD CLASS="quote">i believe PIC makes one, but im not sure if they sell them separately from their suspension, i have the ground control ones but you could even modify your stock top hats if you get someone to weld some pipe onto it.</TD></TR></TABLE>
Yep, the best and easiest way to do it.
Old Nov 11, 2006 | 03:55 PM
Default Re: Top Hat! (dvp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp &raquo;</TD></TR><TR><TD CLASS="quote">Yep, the best and easiest way to do it. </TD></TR></TABLE>
lol i wouldn't say best and easiest, i would say cheapest and cost efficient.
Old Nov 11, 2006 | 06:16 PM
suspendedHatch's Avatar
Well you have the two mounting studs pressed in so it's not as simple as cutting and rewelding an extension pipe unless you have a tool that can cut between those mounting studs.
Old Nov 12, 2006 | 01:41 PM
dvp's Avatar
dvp
I would and did. No other extended top hat is "better". And it's pretty damn easy to do as well. Although it is a bit heavier.
Old Nov 12, 2006 | 09:50 PM
erikiksaz1's Avatar
Default Re: Top Hat! (suspendedHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">Well you have the two mounting studs pressed in so it's not as simple as cutting and rewelding an extension pipe unless you have a tool that can cut between those mounting studs.</TD></TR></TABLE>
You just hammer the studs out! Hah, that was the best part after sawing off the stupid top hat. And after you're done welding, you hammer the studs back in!
Old Nov 12, 2006 | 09:57 PM
Tyson's Avatar
lol. uh yeah, it is that simple.
https://honda-tech.com/zerothread?id=469485
Rob.
Suspension & Brakes
Jul 11, 2009 12:22 AM
MenaceL.A.671
11
Jan 15, 2007 03:56 PM
PabloDiablo
17
Apr 24, 2004 01:31 PM
erikiksaz1
Feb 9, 2004 10:00 PM
asmallsol
Oct 29, 2003 01:19 PM
