d series alternator
Old Nov 9, 2006 | 10:46 PM
lude98SH's Avatar
Default d series alternator
Using the Explict Mount I was thinking about doing a d series alternator along with a lightweight battery. Will I have any problems with dimming lights or power problems? Car will have a flipscreen headunit and just speakers no high powered audio system. The alternator will be from a 92-95 civic.
Old Nov 9, 2006 | 10:50 PM
98vtec's Avatar
moderator emeritus
Default Re: d series alternator (lude98SH)
pm skunked
Old Nov 10, 2006 | 07:44 AM
Hawkze_2.3's Avatar
Get an 85 amp rebuilt alternator from ebay seller 'Alterstart'. I am running one right now with the Odyssey battery you've been asking about and it's stronger than the stock Prelude alternator (or at least stronger than my old one ). I don't think you would have a problem.
They also offer high-power D-series alternators up to I think 300-400 amps if you're not sure
Old Nov 10, 2006 | 01:50 PM
lude98SH's Avatar
Default Re: d series alternator (Hawkze_2.3)
All is see are like 135 amp and higher.
Old Nov 10, 2006 | 02:03 PM
Hawkze_2.3's Avatar
OK, so get a 135 amp
Old Nov 11, 2006 | 06:24 AM
lude98SH's Avatar
What i mean is , is there any disadvantage or possible problem with getting a higher amp alternator ? Keep in mind I will have a lightweight battery so idk if that would be good or bad.
Old Nov 11, 2006 | 08:17 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">What i mean is , is there any disadvantage or possible problem with getting a higher amp alternator ? Keep in mind I will have a lightweight battery so idk if that would be good or bad. </TD></TR></TABLE>
No disadvantage that I kow of...you'll just have more available electrical power to run accessories and charge the battery. Sounds good to me
Old Nov 11, 2006 | 11:14 AM
lude98SH's Avatar
Any performance advantage or disadvantage ? For example lightening the rotating mass on the motor will increase power (ie. power steering removal,balance shaft removal). Will having a higher amp alternator be more stress on the motor or because its pully driven it wont matter regardless ?
Old Nov 11, 2006 | 11:40 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lude98SH &raquo;</TD></TR><TR><TD CLASS="quote">Any performance advantage or disadvantage ? For example lightening the rotating mass on the motor will increase power (ie. power steering removal,balance shaft removal). Will having a higher amp alternator be more stress on the motor or because its pully driven it wont matter regardless ? </TD></TR></TABLE>
OK, I see what you meant...yeah it will be harder to turn and will cause more parasitic loss in hp.
I don't have a radio or anything extra other than some gauges and stuff so I'm good with 85 amps. You'd probably want to get that 135 amp. Stock H alt should be somewhere around 80-90 amp...someone correct me if I'm wrong.
Old Nov 11, 2006 | 11:50 AM
Hawkze_2.3's Avatar
And for anybody who finds this thread looking into a D-series alt here's comparison pics.
Old Nov 11, 2006 | 11:56 AM
UltimX's Avatar
is these both D or is one h and other d? thanks for the comp pic.
Old Nov 11, 2006 | 12:03 PM
Hawkze_2.3's Avatar
Default Re: d series alternator (UltimX)
-Top is from an H23
-Bottom is a rebuilt D-series
Old Nov 11, 2006 | 01:05 PM
darkspector2.0's Avatar
looks like a bit of that weight is the bracket itself
Old Nov 11, 2006 | 02:22 PM
Hawkze_2.3's Avatar
Default Re: (darkspector2.0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector2.0 &raquo;</TD></TR><TR><TD CLASS="quote">looks like a bit of that weight is the bracket itself</TD></TR></TABLE>
Yeah, the alternators probably have no more than a 1lb difference between eachother. It's mainly the brackets and bolts.
Old Nov 11, 2006 | 03:08 PM
UltimX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">-Top is from an H23
-Bottom is a rebuilt D-series</TD></TR></TABLE>
thank you!
Old Nov 12, 2006 | 06:59 AM
prelude_h22vtec's Avatar
so we have to get the bracket to use the dseries alternator?
Old Nov 12, 2006 | 11:01 AM
Hawkze_2.3's Avatar
Default Re: (prelude_h22vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude_h22vtec &raquo;</TD></TR><TR><TD CLASS="quote">so we have to get the bracket to use the dseries alternator?</TD></TR></TABLE>
Yes
Old Nov 12, 2006 | 12:28 PM
If you don't mind me asking, what did you pay for the conversion.. kit+alt??
Old Nov 12, 2006 | 03:10 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkspector2.0 &raquo;</TD></TR><TR><TD CLASS="quote">If you don't mind me asking, what did you pay for the conversion.. kit+alt??</TD></TR></TABLE>
I believe the alternator was $100 or so shipped (I needed a new one badly anyway) and the kit was $78 shipped.
Old Nov 12, 2006 | 09:15 PM
The Birdman's Avatar
Default Re: (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">I believe the alternator was $100 or so shipped (I needed a new one badly anyway) and the kit was $78 shipped. </TD></TR></TABLE>
Not bad. The bracket for the h22/23 is definitely ridiculous and heavy... I will be looking into this for a winter upgrade
Old Nov 13, 2006 | 05:08 AM
Turbocivic94's Avatar
Can they make a bracket for H series alternator?
Old Nov 13, 2006 | 07:25 AM
ha and where did you get the kit? lots of questions get annoying, i know...
Old Nov 13, 2006 | 07:27 AM
98vtec's Avatar
moderator emeritus
http://www.explicitspeedperformance.com
read the thread and you would have known that already
Old Nov 13, 2006 | 07:32 AM
i read "explict mount" in the first post. so wrong spelling+never heard of the site= i ask questions
tim_r95
Jan 27, 2015 08:02 AM
doubledee
Jul 27, 2008 02:43 PM
contreras89
Honda Civic (2001 - 2005)
Jan 29, 2008 12:37 AM
roadhead
Audio / Security / Video
Jul 21, 2006 11:47 AM
l@rryd
Sep 18, 2003 09:36 PM
