tips on removing tranny with motor in car
Old Nov 9, 2006 | 09:28 PM
xxmastermindxx's Avatar
Default tips on removing tranny with motor in car
seems like its not possible, the last thing i have left to remove is the right radius rod and then it SHOULD slide on out. ill be doing this saturday morning, just looking for any tips before i tackle it.
Old Nov 9, 2006 | 09:33 PM
jgonzbb1's Avatar
Default Re: tips on removing tranny with motor in car (xxmastermindxx)
Make sure you use something to support it. I used a rolling jack. As I slid the tranny away from the motor it was a smooth transition. Make sure you jack it up enough. If you have an extra pair of hands have them watch for the tranny if it leans forward or backword. Hope that helps good luck.
Old Nov 10, 2006 | 03:09 AM
pentaq's Avatar
Default Re: tips on removing tranny with motor in car (jgonzbb1)
I skipped the radius rod. I just pulled it to the side and tranny just went under it (there's a tab which interferes the rod)
Old Nov 10, 2006 | 04:38 AM
117's Avatar
117
Removing the entire front subframe along with the radius rods makes the tranny much easier to R&R, but that requires that you remove the front engine mount, so supporting the engine is an absolute must. It only takes a few minutes, and you don't have to fight to R&R the tranny.
Old Nov 10, 2006 | 05:40 AM
alterdcreations's Avatar
Default Re: (117)
Old Nov 10, 2006 | 03:52 PM
PrecisionH23a's Avatar
Default Re: tips on removing tranny with motor in car (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">I skipped the radius rod. I just pulled it to the side and tranny just went under it (there's a tab which interferes the rod)</TD></TR></TABLE>
Pull the radius rods... it makes it 3x easier.
Old Nov 10, 2006 | 05:10 PM
mgags7's Avatar
definitely pull the radius rods....and it has always been my preference to just let the trans fall onto my chest.....jacks are for pussies....lol
Old Nov 10, 2006 | 05:21 PM
del_parker's Avatar
Radius rod is really simple to pull.
Old Nov 10, 2006 | 06:08 PM
98vtec's Avatar
moderator emeritus
Default Re: (bb4ever)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">definitely pull the radius rods....and it has always been my preference to just let the trans fall onto my chest.....jacks are for pussies....lol </TD></TR></TABLE>
is that like manlaw or something?
tranny jack ftw
and yes, definitely remove the radius rods. I had to remove one of the studs from the tranny that go to the mount to allow the tranny to slide off the main shaft and clear the chassis
Old Nov 12, 2006 | 07:24 PM
Default Re: (98vtec)
thanks for all the tips
there is only one radius rod on the tranny side, right?
and as far as the entire front subframe, what exactly does that include? i didnt get to it this weekend, but this coming weekend ill definitely go at it.
thanks again guys
Old Nov 12, 2006 | 09:25 PM
mgags7's Avatar
If you wanted to drop the front subframe, you would have the 7 bolts to drop the under-engine brace, the front motor mount, both radius rods, then the 6 bolts to drop the actual subframe....really not too bad....
Just BE SURE to either mark where the bolts are for the radius rods or only unbolt them from the control arm.....they influence your alignment, and if you just loosen them out of the subframe you will lose all adjustment....
yeah lets man law that
no tranny jacks, the proper way to drop a transmission is onto your stomach
Old Nov 12, 2006 | 11:05 PM
CGags13's Avatar
thats sto-mach in Borat language
Old Nov 12, 2006 | 11:20 PM
LudeBehavi0r's Avatar
&lt;---vividly remembers your face when the diff inched closer and closer to your lips....
But yea, taking out the radius rods is def a plus/its 100% worth it to take the time. Otherwise you just end up smashing into other 'ish and getting really reallllly realllly frustrated.
Old Nov 13, 2006 | 03:18 AM
117's Avatar
117
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">Just BE SURE to either mark where the bolts are for the radius rods or only unbolt them from the control arm.....they influence your alignment, and if you just loosen them out of the subframe you will lose all adjustment....</TD></TR></TABLE>
How are the radius rods adjustable from the factory (other than shims)?
Old Nov 13, 2006 | 03:58 AM
Revi's Avatar
Default Re: (117)
I would remove the engine 10 times before i remove just the tranny. But then again when i removed the tranny it was by my self. I just find removing the eingine to be alot easier than removing just the tranny.
Old Nov 13, 2006 | 04:17 AM
pentaq's Avatar
Default Re: tips on removing tranny with motor in car (del_parker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by del_parker &raquo;</TD></TR><TR><TD CLASS="quote">Radius rod is really simple to pull.</TD></TR></TABLE>
yeah, I have just broken one and bent another wrench on the front nut of the radius rod. This rod is a really sucker.
Old Nov 13, 2006 | 01:04 PM
mgags7's Avatar
Default Re: (LudeBehavi0r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeBehavi0r &raquo;</TD></TR><TR><TD CLASS="quote">
But yea, taking out the radius rods is def a plus/its 100% worth it to take the time. Otherwise you just end up smashing into other 'ish and getting really reallllly realllly frustrated. </TD></TR></TABLE>
lol f you maacus....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 117 &raquo;</TD></TR><TR><TD CLASS="quote">
How are the radius rods adjustable from the factory (other than shims)?</TD></TR></TABLE>
they're different on 4th gens than on 5th, the front bolts into the subframe, and the amount you tighten the nut on controls the caster....
I believe the 5th gens have multiple sets of radius arms at different lengths that can be ordered.....
Old Nov 13, 2006 | 01:06 PM
The Birdman's Avatar
sto mach. haha
Old Nov 13, 2006 | 01:16 PM
117's Avatar
117
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">they're different on 4th gens than on 5th, the front bolts into the subframe, and the amount you tighten the nut on controls the caster....</TD></TR></TABLE>
I don't have my 4Gen Helms manual handy, but I thought the 4Gen and 5Gen base model radius rod assemblies were identical, no?
On a 5Gen, there is a shim, two bushings, spacer, and a nut. The nut is torqued to 40 ft*lbs. There is no caster adjustment other than adding/removing shims. The 4Gen is different? I'm not doubting you, I'm seriously asking. I haven't done much suspension work on 4Gens, so I've never noticed if they're different or not.
According to San Leandro Honda the diagram for the 4Gen front lower arm assembly is:
5Gen base:
Interestingly enough, the radius rods are different PNs, but the LCAs are the same PN. The shims are the same PN, but the spacers are not. So the radius rods are not the same, but neither appear to be adjustable.
If the 4Gen is adjustable, I'd like to see some pictures because I'd adapt this to my 5Gen spherical bearing setup so I could have adjustable caster!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">I believe the 5th gens have multiple sets of radius arms at different lengths that can be ordered.....</TD></TR></TABLE>
For the SH, there are multiple radius rods available for different caster settings due to the attachment between the radius rod and front subframe. For the base, the radius rods are set up just like the 4Gen.
Old Nov 13, 2006 | 01:21 PM
Eddiebx's Avatar
its not how tight you tighten the nut, u just put shims on the rod to move the caster around.
Old Nov 13, 2006 | 01:24 PM
117's Avatar
117
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">its not how tight you tighten the nut, u just put shims on the rod to move the caster around.</TD></TR></TABLE>
Darn, that's what I was thinking.
Old Nov 13, 2006 | 01:26 PM
mgags7's Avatar
That seems fine to me, but since there is a rubber bushing behind there, it seems that any movement of that nut is going to adjust caster.
There is no way you could just tighten it down to the same spot every time, even though there is a set tq for that nut....rubber isn't exact enough to do that.....right??
and yes, i was thinking of the SH when I said that
Old Nov 13, 2006 | 01:49 PM
117's Avatar
117
The rubber is compliant enough that when you torque the nut, the washers hit the metal spacer (aka collar, as Honda calls it), so you are torquing the nut in the same place every time unless you change the spacer or add/remove a shim.
Old Nov 13, 2006 | 01:57 PM
mgags7's Avatar
gotcha....thanks
Old Nov 14, 2006 | 11:07 AM
makes sense now. I always thought wrenching down on the nut would adjust caster a little, but i guess its safe to say we can throw that out of the window now.
spens 91 Ef
Mar 2, 2009 04:46 PM
0ptimus prime
Jun 27, 2004 12:12 PM
dan89crxsi
Oct 27, 2003 09:57 AM
cr-x si
16
Jun 19, 2003 09:13 PM
Shaun
Apr 8, 2003 07:49 PM
