lowering springs?
Old Nov 9, 2006 | 07:11 AM
SLO Sol's Avatar
Default lowering springs?
will springs from a 98 civic coupe fit on my 1992 hatch posted in suspension also
Old Nov 9, 2006 | 07:12 AM
ricanxplaya's Avatar
Default Re: lowering springs? (D-money 92si)
probably yeah
Old Nov 9, 2006 | 07:13 AM
92'si's Avatar
for sure buds
Old Nov 9, 2006 | 10:28 AM
SL!M's Avatar
roger that.
Old Nov 10, 2006 | 07:24 AM
SLO Sol's Avatar
will the 98 coupe struts fit also?
Old Nov 10, 2006 | 07:33 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si &raquo;</TD></TR><TR><TD CLASS="quote">will the 98 coupe struts fit also?</TD></TR></TABLE>
The fronts bolt in exactly the same, but the EK ones lack brake hose holders, so you'll need to secure the lines with zip ties.
The rear will only work if you grind the rear lower control arm bushing thinner where the lower fork of the strut slides over the bushing. EK struts are the exact same dimensions EXCEPT the lower fork is thinner.
I'm running Koni Yellows intended for an EK on my EG, so this is first-hand info, not hearsay.
Old Nov 10, 2006 | 12:31 PM
SLO Sol's Avatar
Default Re: lowering springs? (B18C5-EH2)
would it just be smarter for me to take the springs off the EK struts and put them on my EG struts
Old Nov 10, 2006 | 12:42 PM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si &raquo;</TD></TR><TR><TD CLASS="quote">would it just be smarter for me to take the springs off the EK struts and put them on my EG struts</TD></TR></TABLE>
Depends on the condition of your EG struts versus the EK ones honestly.
If you want to do it the right way I'd look into just buying new struts anyways. The ride quality is so much nicer on new struts than old Eg or even EK ones on lowering springs.
Old Nov 10, 2006 | 12:58 PM
SLO Sol's Avatar
i should prolly add that its coming off an EX-EK and going onto a Si-EG
Lacrossekid183
17
Oct 4, 2012 12:38 PM
sinesterxone
Apr 4, 2006 01:53 AM
myronwong
12
Feb 5, 2006 03:47 PM
Bigjussin
15
May 22, 2004 10:40 AM
piscorpio
Nov 7, 2002 01:43 AM
