lowering springs?
Former Moderator
Re: lowering springs? (D-money 92si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si »</TD></TR><TR><TD CLASS="quote">will the 98 coupe struts fit also?</TD></TR></TABLE>
The fronts bolt in exactly the same, but the EK ones lack brake hose holders, so you'll need to secure the lines with zip ties.
The rear will only work if you grind the rear lower control arm bushing thinner where the lower fork of the strut slides over the bushing. EK struts are the exact same dimensions EXCEPT the lower fork is thinner.
I'm running Koni Yellows intended for an EK on my EG, so this is first-hand info, not hearsay.
Former Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-money 92si »</TD></TR><TR><TD CLASS="quote">would it just be smarter for me to take the springs off the EK struts and put them on my EG struts</TD></TR></TABLE>
Depends on the condition of your EG struts versus the EK ones honestly.
If you want to do it the right way I'd look into just buying new struts anyways. The ride quality is so much nicer on new struts than old Eg or even EK ones on lowering springs.
sinesterxone
04-04-2006 01:53 AM
Bigjussin
15
05-22-2004 10:40 AM
piscorpio
11-07-2002 01:43 AM
