Clutch pedal acting up
Old Nov 9, 2006 | 07:03 AM
TheAccordGuy's Avatar
Default Clutch pedal acting up
In my EG civic for some reason my clutch pedal is sticking and not coming up all the way. I think it may because someone adjusted the pedal wrong before I got the car or that my slave cylinder is going out. When I left up the hood the salve cylinder seems compressed and not released when the car in park any suggestions.
Old Nov 9, 2006 | 07:07 AM
jadugartir's Avatar
Default Re: Clutch pedal acting up (TheAccordGuy)
When this happened to my friends hatch it was his slave cylinder. I think he got one from autozone for like 25 bucks or so.
Old Nov 9, 2006 | 07:09 AM
NSfit's Avatar
i had the same problem you need to fix it now.... its your clutch slave cylinder. when i had it i ignored it and on my way home one day the clutch pedel fell to the ground and didnt come back up. there is just a leak in the cylinder and when enough fluid leaks out yours will do the same. CHANGE IT SOON
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Check that the slave cylinder isnt leaking. I had a problem in my Prelude where the slave cylinder would just slightly leak overnight allowing the pedal to fall. IDK just a shot.
Old Nov 9, 2006 | 07:28 AM
dognutz's Avatar
Default Re: Clutch pedal acting up (NScivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NScivic &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem you need to fix it now.... its your clutch slave cylinder. when i had it i ignored it and on my way home one day the clutch pedel fell to the ground and didnt come back up. there is just a leak in the cylinder and when enough fluid leaks out yours will do the same. CHANGE IT SOON</TD></TR></TABLE>
This same thing happened to me on the beltway i had to reach down while driving and pull it back up. The first time it happened I was about to sh*t my pants.
You should replace the master and the slave at the same time. Look on the floor behind your pedal and look for fluid. This is the sign of a bad master cylinder. GL.
Old Nov 9, 2006 | 07:31 AM
crimsonv4mpire's Avatar
slave.
Old Nov 9, 2006 | 08:14 AM
CodyC142's Avatar
Default Re: Clutch pedal acting up (crimsonv4mpire)
I would have to agree with the others and say slave
My car does something like that, but my clutch pedal jsut has like 2 inches of play before the clutch actually does anything.. I might change it tomorrow
Good luck on the repair
-Cody
Old Nov 9, 2006 | 10:41 AM
dognutz's Avatar
Default Re: Clutch pedal acting up (CodyC142)
I was only stating that you might as well do both and have all new components, especially with the age of the vehicle. The masters are known to fail i have already replaced 2 so it's just to be safe.
Old Nov 9, 2006 | 04:41 PM
Yeah I was thinking it may be the salve thank a lot for your help and I will post results after I replace it.
zach1288
Jan 21, 2010 03:16 PM
lsvtec97hatch
Aug 5, 2009 11:21 AM
vinceg143
Sep 9, 2008 07:14 AM
crxricer66
Dec 1, 2007 07:58 PM
majinx4
Jun 14, 2006 05:46 AM
