OBD-II GSR --> 94 VX
Old May 7, 2002 | 12:30 PM
navin's Avatar
Default OBD-II GSR --> 94 VX
Ok I think I have been getting some mis-information. But what would have to be done to the harness for my OBD-II motor swap to go into an OBD-I car.
I thought and read that the harness plug in on the passenger side, and for the ECU I got an OBD-I p72 ECU. Anything Im missing here?
Thanks
Old May 7, 2002 | 12:44 PM
oldbeefcake's Avatar
Default Re: OBD-II GSR --> 94 VX (navin)
just plug all together and rewire the knock sensor and the IAB which you have to add this to the plug. That is it. I got a 92 vx with a 98 motor, it works fine.
Old May 7, 2002 | 12:52 PM
navin's Avatar
Default Re: OBD-II GSR --> 94 VX (Jun)
so basically - all the harness' that come with the motor will plug right into my civic harness (under hood harness)..?
I think I might have mis-understood the guy's question - but just verifying.
Old May 7, 2002 | 05:08 PM
navin's Avatar
any other opinions..?
Old May 7, 2002 | 05:37 PM
JeffS's Avatar
Jun is correct. I just did the same swap.
The engine harness of a US model B18 will plug right into your car. If you have a JDM engine, it's another story entirely.
good luck
Old May 7, 2002 | 05:39 PM
navin's Avatar
Default Re: OBD-II GSR --> 94 VX (JeffS)
*phew* awesome guys, now what about injectors.
[sidenote] anyone think OBD-II is a pain in the ***, i wish i just had got an old *** OBD-I and built it up [/sidenote]
Old May 8, 2002 | 12:45 PM
don't worry about the injectors, just do the wires. that's all you need. let me know if you get codes after you start it up.
Old May 8, 2002 | 11:52 PM
Roger's Avatar
Jun: Got a few questions for you: What about the two O2 sensors that the OBD2 wire harness has? And the sensor thats on top of the B18C1 OBD2 intake manifold? Does he need that sensor ?? Thanks
Old May 9, 2002 | 12:44 AM
Katman's Avatar
Default Re: OBD-II GSR --> 94 VX (Roger)
if you run an OBD1 ecu, you don't need to worry about wiring up the OBD2 sensors such as the CKP (sensor on oil pump), second 02, and I think that black sensor ontop of the GSR manifold, like what you're talkin about. THe OBD1 ecu's aren't programmed to look for those additional sensors.
Old May 9, 2002 | 07:22 AM
Default Re: OBD-II GSR --> 94 VX (Katman)
Katman knows lot more than me, just take his advice. I have one plug near the battery that doesn't plug up, i did some search it has 3 wire in that plug, I know two of them for sure, it is the CKF power and ground, (it is not needed for OBDI)Not sure about the RED wire, I looked in the Helm, but can't figure out, I though it was the EVAP. The second O2 doesn't run on the engine harness, when I was running on OBDII ECU, I had to wire it directly to the ECU.
Alex V
Jul 5, 2019 10:46 AM
v8killaz
May 15, 2010 03:07 PM
asigler
Jul 22, 2009 10:59 AM
efjuice
Oct 28, 2004 11:10 AM
EARLdaSQUIRREL
Aug 20, 2003 08:13 PM
