Engine cutting out and tach going nuts, help.
Old Nov 8, 2006 | 11:52 PM
OMG WTF's Avatar
Default Engine cutting out and tach going nuts, help.
I just purchased a vehicle from a well known forum member. The person failed to mention quite a few things during the sale regarding the vehicle.
First, the engine seems to sputter pretty hard. I know the car needs a new tuning session so i just figure its because of the bad tune. Upon further investigation its actually the engine fully cutting off or shutting down. some times it sputters intermittently for a few seconds at a time, sometimes it sputters until the engine fully shuts off for a second and kicks back in. When the car sputters the tach and speedo shuts off too. I also looked at the sellers old post and he states that this occured when he tried drag racing for the first time. All this leads me to believe theres a loose connection somewhere, im not to familiar with Hondas so could someone give me a suggestion on where to look first.
Second, the tach goes bizzerk when revving in the upper RPM range. When cruising its fine. WTH.
TIA
Old Nov 9, 2006 | 08:05 AM
sewell94's Avatar
This sounds like a ground wire issue, check your grounds, one on the thermostat housing which thats for the wiring harness, also check the ground that goes from the frame rail to the tranny, and the ground on the battery that goes to the frame, make sure the connections are tight and both surfaces are clean.
Old Nov 9, 2006 | 03:32 PM
OMG WTF's Avatar
Thanks for the advise, ill check that when i get home.
Anymore ideas is much appreciated.
Old Nov 9, 2006 | 11:56 PM
sewell94's Avatar
Could also be your ignitor going out.
Old Nov 10, 2006 | 12:33 AM
OMG WTF's Avatar
The guy said he changed the ignitor right before i picked the car up. besides, would the ignitor cause the tach and speedo to go out?
Old Nov 10, 2006 | 04:19 AM
EE_Chris's Avatar
Default Re: (OMG WTF)
If you had only said the tach was jumping, I'd suggest ignitor (ICM). But since you said tach and speedo, that does sound more like an intermittent connection of some sort - perhaps a ground. From where did the guy buy the ICM he replaced? Hopefully it's OEM because 3rd party ignition components don't seem to make the grade that OEM does.
Old Nov 10, 2006 | 05:16 AM
chiman72's Avatar
Default Re: (EE_Chris)
the distributor is about to go. (ignition control module)
Old Nov 10, 2006 | 08:29 AM
OMG WTF's Avatar
ok ill have the distributor checked.
he changed it to an autozone ignitor.
thanks for the input.
just a reminder, according to the previous owners old post that i dug up in the archives this problem first occured after a night of drag racing on the way home.
anymore suggestions?
Old Nov 10, 2006 | 08:31 AM
OMG WTF's Avatar
BTW i checked the engine and transmission ground. the engine ground is fine, the transmission ground seems to be missing however i dont know for sure until i figure out how to remove this huge *** Mugen intake to check.
Modified by OMG WTF at 11:29 AM 11/10/2006
wnp94
Sep 23, 2014 10:10 PM
SuperSlowH22
Oct 25, 2005 04:43 PM
datac99
May 23, 2005 01:52 PM
arqtect
Nov 26, 2004 03:13 PM
crxtreme27
May 5, 2003 07:15 AM
