gsr swap wiring problem! need help asap!
i'm swapping a 01 b18c1 into a 98 civic hb
i bought a 98 ex harness from the junk yard and installed it the other day. now the problem i have is that there are a couple of circular plug under and on the intake manifold. i think there are 4 sensors iab, iac, ect with the exact same plug, but the wiring harness only has 3 of the circular plug. now i dont know which one is suspose to be unplugged or if i need to run an extra plug. i need help asap because the motor is going in tomorrow. thanks in advance.
ok first of all retype or edit your post because it doesn't make sense (try proofreading) not try to be a smartass but you make the problem more confusing than it already is. QUOTE[there are a couple of circular plug under and on the intake manifold. ] what does that mean?
Anyway to the problem; i think the plugs you are reffering to are the IAB,IAT,IAC,and i believe the purge. With the ex harness you will not have the IAB and it will have to be hardwired. Also the purge on a 01 gsr i believe is a square black plug and the solenoid is located on the top of the intake manifold. I am not certain if the 98 ex harness used a round plug for the purge like older tegs and civics or if it has the same plug as the 01 gsr. to round things off i believe all you will be short is one plug for the IAB which will have to be hardwired.
rice4life
Mar 9, 2004 03:46 AM
