How do u take off a Throttle Body ??
i need to take it off my 90 gs 2dr teg so that i can chnage the TPS , it broke when i bought an intake manifold
how do i do this ??? and also how do u take off the TB ??
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qfast817 »</TD></TR><TR><TD CLASS="quote">you unbolt the 4 12mm bolts/nuts then to change the tps u have to knotch the caped bolt and use a flathead to remove it</TD></TR></TABLE>
The older integras just have phillip screws holding the TPS on. Basically what he said, take the intake off (CAI, stock rubber pipe....whatever you've got), then take the coolant lines off the bottom, unplug the connectors and 4, 12mm bolts/nuts later its off.
Vp Special K
Apr 8, 2003 07:58 PM
