cylinder bore question
Old Nov 8, 2006 | 07:55 PM
igotthaspirit's Avatar
Default cylinder bore question
I have a B18C1 that needs bored out. I noticed that most of the overbored pistons you can get are .020" over. Does that mean I need to have the block bored out .020" over stock or do I need to have it bored out more to allow for the ring clearance?
Old Nov 9, 2006 | 06:52 AM
lightcrx's Avatar
it depends how bad the walls are if there not bad then a .10(81.25) over will do but you might have to do a .20 over witch would make your stock b18c1 81.5mm, so you first buy the pistons then give them to the machine shop and he will measure the pistons and bore the block to the spec sheet(that comes with the pistons)
Old Nov 9, 2006 | 07:11 AM
attentionwhore's Avatar
From: ...and then along comes the fcuking policia, PA
Default Re: (lightcrx)
Yea, what he said ^^^^
I am putting 81.25 JDM ITR pistons in my gsr block and I plan to do the same thing.
Project_EK
Feb 3, 2007 10:20 AM
I_got_your_honda
Aug 17, 2006 01:04 PM
JDMotive
May 28, 2004 02:26 PM
gtcali
Jun 14, 2002 03:49 AM
Captain Save-a-Hoe
May 10, 2002 07:42 PM
