After MSD Install car is acting up
Old Nov 8, 2006 | 02:20 PM
RedSiHatch's Avatar
Default After MSD Install car is acting up
I just installed an MSD ignition on my 96 integra LS (wires, cap, rotor, blaster coil ss, and 6AL box. I soldered the wires and made sure everything is in the right place. The car starts, but for some reason no more than a minute the car is on it loses spark and it shuts off. It will not crank right back up immediately, but after a minute or two it will start and then the same thing, it shuts off. I think my igniter might be bad. One of my buddies told me when the igniter heats up, it might create a lot of resistance and it cannot handle all of the power from the MSD so the car will shut down. PLEASE HELP!!!!
Old Nov 8, 2006 | 02:31 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: After MSD Install car is acting up (RedSiHatch)
What all do you have done to the car? Stock Honda ignition can handle somewhere around 400 HP. Unless you are boosted you really don't need MSD. I had it on my car (NA) and took it off to realize it ran so much better without.
Old Nov 8, 2006 | 04:04 PM
skunked's Avatar
Default Re: After MSD Install car is acting up (SlammedDC2)
MSD's tend to fail and like already mentioned above the oem ignition is more than capable of handling the job.
Old Nov 8, 2006 | 04:34 PM
RedSiHatch's Avatar
well i am running a 100 shot and crane cams and i figured it would help out some and i got it cheap from a friend. It was working fine on his car.
Old Nov 8, 2006 | 05:24 PM
SlammedDC2's Avatar
Semper Fidelis
Default Re: (RedSiHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedSiHatch &raquo;</TD></TR><TR><TD CLASS="quote">well i am running a 100 shot and crane cams and i figured it would help out some and i got it cheap from a friend. It was working fine on his car.</TD></TR></TABLE>
I don't know about spray, never dealt with it. But you don't need it just for cams. You said your friend had it on his car, what did he have done? And why did he take it off?
Old Nov 9, 2006 | 06:43 AM
chino00's Avatar
i have a 2000 gsr running around 7 psi of boost and im thinking about getting a new wires set plugs dist and rotor just wondering if i should go with a cold temp ngks or spring for more expensive msd's? thanks for any info
Old Nov 9, 2006 | 07:26 AM
95 integra's Avatar
How do your connections look where you soldered them? Did the solder suck into the wire like its suppose to? Also, did you check your timing after you installed the MSD? The MSD makes the signal travel further (resisitance in the wire/box, etc) thus you generally have to advance the ignition to make up for the lag in the electronic pulse. If you didnt, get a timing light and do that.....do NOT just randomly play with the distributor.
Old Nov 9, 2006 | 08:05 AM
SlammedDC2's Avatar
Semper Fidelis
Default Re: After MSD Install car is acting up (95 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chino00 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 2000 gsr running around 7 psi of boost and im thinking about getting a new wires set plugs dist and rotor just wondering if i should go with a cold temp ngks or spring for more expensive msd's? thanks for any info </TD></TR></TABLE>
As I already stated, if your not putting down more than 400hp you don't need it. You said your running 7psi so i seriously doubt you are past 265-290. So I don't think you need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">How do your connections look where you soldered them? Did the solder suck into the wire like its suppose to? Also, did you check your timing after you installed the MSD? The MSD makes the signal travel further (resisitance in the wire/box, etc) thus you generally have to advance the ignition to make up for the lag in the electronic pulse. If you didnt, get a timing light and do that.....do NOT just randomly play with the distributor.</TD></TR></TABLE>
That's right, I forgot about advancing the timing.
Old Nov 9, 2006 | 08:28 AM
chino00's Avatar
ok thanks for the info slammed
Old Nov 9, 2006 | 08:05 PM
RedSiHatch's Avatar
I found the problem, the actual MSD 6AL box is messed up. i wired my blaster ss coil to my distributor and it started up and never died. Its been running great ever since.
Old Nov 10, 2006 | 07:29 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedSiHatch &raquo;</TD></TR><TR><TD CLASS="quote">I found the problem, the actual MSD 6AL box is messed up. i wired my blaster ss coil to my distributor and it started up and never died. Its been running great ever since.</TD></TR></TABLE>
not surprising, glad you figured it out
Old Nov 10, 2006 | 09:07 AM
JDMorgan's Avatar
Default Re: After MSD Install car is acting up (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">MSD's tend to fail and like already mentioned above the oem ignition is more than capable of handling the job.</TD></TR></TABLE> they need a super good ground or they act a fool. took me forever to find one then i pulled it back out after a couple weeks. waste of money.
stick to oem distributor(cap and rotor too), oem or ngk wires, and ngk plugs.
darkstar1440
Jul 27, 2006 07:54 AM
elusive123
Jun 18, 2005 07:16 PM
K-Spec
Jan 8, 2005 03:48 PM
BLKCRX
Nov 15, 2002 10:04 AM
batboy18
Aug 26, 2001 05:01 PM
