gsr turbo or supercharged
Old Nov 8, 2006 | 11:46 AM
NAmodified's Avatar
Default gsr turbo or supercharged
Car 99 gsr
All i see on honda tech is how turbo is the best.... well Wat about supercharging, looking for some advice on which f.i. setup i should go for. I noticed that most superchargers are carb legal , while gredy is the only company i can find that makes a carb legal turbo kit, which i hear isnt to great ... What do u think/ recommend?
Old Nov 8, 2006 | 11:54 AM
rotorhead's Avatar
id say go with the supercharger. imo integras need the low end power
Old Nov 8, 2006 | 12:07 PM
tweekerz's Avatar
Default Re: (rotorhead)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rotorhead &raquo;</TD></TR><TR><TD CLASS="quote">id say go with the supercharger. imo integras need the low end power</TD></TR></TABLE>
Yeah if you can put it down to the wheels.
Old Nov 8, 2006 | 12:26 PM
qwk db8's Avatar
Default Re: gsr turbo or supercharged (NAmodified)
TURBO
Old Nov 8, 2006 | 12:38 PM
NokStrImpz's Avatar
Turbo!Turbo!Turbo!Turbo!Turbo!Turbo!Turbo!Turbo!Tu rbo!Turbo!Turbo!Turbo!
Old Nov 8, 2006 | 12:39 PM
PrinceAli132's Avatar
As nice as superchargers are, you still have to worry about engine temps. And then there is a problem with turning up the boost. You might be able to reach 10-12 psi but after that to my knowledge your maxed out.
Atleast with a turbo you have better intercooler options and have less limitations on max power. Also, you could get a smaller dual ball bearing turbo to help on the low end like a GT28R.
Ali
Old Nov 8, 2006 | 02:53 PM
1turbodc2's Avatar
turbo FTW, simple fact supercharge's just don't go well with out cars, turbo's are the way to go, room to expand, and more reliable.. i have had my car under boost for over a year and a half and the car runs great!
Old Nov 8, 2006 | 03:52 PM
NAmodified's Avatar
Default Re: (1turbodc2)
ok turbo guys is it carb legal?
Old Nov 8, 2006 | 04:05 PM
tweekerz's Avatar
Default Re: (NAmodified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified &raquo;</TD></TR><TR><TD CLASS="quote">ok turbo guys is it carb legal? </TD></TR></TABLE>
There are carb legal kits if you are worried. Greddy and Edelbrock are a few.
Old Nov 11, 2006 | 06:15 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAmodified &raquo;</TD></TR><TR><TD CLASS="quote">Car 99 gsr
All i see on honda tech is how turbo is the best.... well Wat about supercharging, looking for some advice on which f.i. setup i should go for. I noticed that most superchargers are carb legal , while gredy is the only company i can find that makes a carb legal turbo kit, which i hear isnt to great ... What do u think/ recommend?</TD></TR></TABLE>
you can find a used supercharger for less than a turbo kit, but it's not going to give you as much power.
Old Nov 11, 2006 | 06:27 PM
gsr_pimp88's Avatar
well doesnt a supercharger rob power from the engine inorder to run it b4 it gets u gains? turbo uses ur exhaust waste to generate power. i dont think a supercharger is a good idea for a 4 cylinder car, not enough power to make it reasonable for the gains, turbo is my choice
Old Nov 11, 2006 | 07:20 PM
vladd's Avatar
Default Re: (gsr_pimp88)
yeah, superchargers use engine power to run. that's why they make less power than a similar psi turbo setup. you can still make decent power with a supercharger on a 4 cylinder, just not as much as a turbo. it just depends on how much you wana pay.
Modified by civicdxtyper at 9:35 PM 11/11/2006
Old Nov 11, 2006 | 07:32 PM
aaronISthrowed's Avatar
Default Re: (civicdxtyper)
turbo
Old Nov 11, 2006 | 10:01 PM
VeryTallEngineCoolant's Avatar
s/c is good and all but I dont think you can make same amount of power with turbo..So I say Turbo..and plus that sound everyone knows.."PSSSSHHHH"..
milano2kdc2
Feb 16, 2006 07:41 PM
kevin85193
Aug 4, 2005 03:12 PM
killablaze
Nov 17, 2004 07:22 PM
vod
Jan 12, 2004 01:21 PM
xstalkrx
May 27, 2003 09:14 PM
