need help with b18 block
Old Nov 8, 2006 | 07:22 AM
matt c's Avatar
Default need help with b18 block
i killed my motor i have a 99 gsr and i was wondering if i could use a 94 block i have been told i could and i couldent
so if i can what will i have to change
Old Nov 8, 2006 | 07:31 AM
97itypeR's Avatar
im pretty sure u can because i mean...if u can take a b16head and put it on a LS block, wouldnt that be MORE than enough evidence that u can mix and match the years of head/blocks?
Old Nov 8, 2006 | 08:43 AM
95 integra's Avatar
Default Re: (97itypeR)
Yes, you can, you will need to change out the oil pump to be able to hook up the crank position sensor. Other then that I believe the blocks are identical.
Old Nov 8, 2006 | 08:57 AM
POE's Avatar
POE
yes the obd2 has an crank position sensor and the 94 (obd1) doesnt. SO change that and u are good to go
Old Nov 8, 2006 | 08:58 AM
krweby's Avatar
Like 95 integra said the blocks are the same but you will need to change the oil pump so you can hook up the crank sensor.
Old Nov 8, 2006 | 08:59 AM
1997 gsr's Avatar
Default Re: (POE)
its the same size motor. i dont see why u couldnt because like one dude said u can switch up heads with blocks. so good luck
Old Nov 9, 2006 | 10:27 AM
97itypeR's Avatar
thank you i take credit for that head/.block mix :thumbsup:
Old Nov 9, 2006 | 11:56 AM
95 integra's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itypeR &raquo;</TD></TR><TR><TD CLASS="quote">thank you i take credit for that head/.block mix :thumbsup:</TD></TR></TABLE>
You take credit for what?
Old Nov 9, 2006 | 03:00 PM
GoldCoin's Avatar
Default Re: (95 integra)
i guess he sees <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1997 gsr &raquo;</TD></TR><TR><TD CLASS="quote">its the same size motor. i dont see why u couldnt because like one dude said u can switch up heads with blocks. so good luck</TD></TR></TABLE>
so he wants to say <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97itypeR &raquo;</TD></TR><TR><TD CLASS="quote">thank you i take credit for that head/.block mix :thumbsup:</TD></TR></TABLE>
and then your wondering<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra &raquo;</TD></TR><TR><TD CLASS="quote">You take credit for what?</TD></TR></TABLE>
but i say i doesnt matter cuz your still helping someone out
FeelinKoopish
Apr 13, 2008 03:18 PM
turbodohcsi
Jan 10, 2005 04:07 PM
Huee
Mar 1, 2004 12:53 PM
riceburnah
May 29, 2003 09:30 AM
6pucker
May 26, 2002 10:42 PM
