b18b(obd1) block with obd2 b18b head?
Old May 29, 2003 | 09:27 AM
riceburnah's Avatar
Default b18b(obd1) block with obd2 b18b head?
is there going to be any problems with swapping a 97 ls block with a 94 ls block since the block is obd1 if so what do I need?
Old May 29, 2003 | 09:30 AM
Scott - 93HB Si's Avatar
Default Re: b18b(obd1) block with obd2 b18b head? (ihaterice8)
need to add the crank flux sensor that sits around the main crank pulley, but on the inside near the belt. You will also need the Tbelt drive gear from the OBD2 cuz it has teh flux sensor trigger on it.
Other than that, easy stuff.
matt c
Nov 9, 2006 03:00 PM
AiL45
Oct 27, 2006 03:28 PM
THE GUY
Apr 8, 2006 09:07 PM
Yuleluder
Nov 1, 2005 07:53 PM
crazyfastteg
Apr 27, 2005 05:23 PM
