Anyone using... SSAC T3 Super 70... Already searched and read the SSAC Thread!!!
Old Nov 7, 2006 | 03:57 PM
chasemyhonda's Avatar
B A N N E D
Default Anyone using... SSAC T3 Super 70... Already searched and read the SSAC Thread!!!
NO bashing. Do not tell me to do it right the first time. its my money and i wanna try it out. if i fail then its my bad.
Basically i want to know...
When do you start making boost.. and when do you reach full boost.
Are you running a oil rerstrictor?
what kind of power are you making?
Here is what they have listed as the specs on the turbo
T3 Super T-70 Turbo
Specifications
Nomenclature (tag ID)
T3 Super T70
Inlet (exducer/hot side)
T-3 Flange
Outlet (exducer/hot side)
3” V-Band
Inlet (compressor/cold side)
Ø 102mm (4”)
Outlet (compressor/cold side)
Ø 65mm (2.5”)
Exducer A/R
0.84
Compressor Style
0.70
Bearing Type
plain
Cooling/Lubrication
Oil/Oil
Oil Supply Fitting
Flange
Oil Return Fitting
Flange
Compressor major diameter
Ø 84 mm
Old Nov 7, 2006 | 04:41 PM
I Have an STD's Avatar
wrenchin'
how much do they go for? i've heard a restrictor is the way to go with the ssac turbos. no bashing here
Old Nov 7, 2006 | 04:45 PM
drintegra's Avatar
Default Re: (I Have an STD)
Here is the link 274 buy it NOW
http://cgi.ebay.com/ebaymotors...QrdZ1
Old Nov 7, 2006 | 04:55 PM
ATYPR's Avatar
Default Re: (drintegra)
https://honda-tech.com/zerothread?id=1554048
It made 485rwhp and 525rwtq on 6psi.
Now it has a Turbonetics T4 and it makes over 500whp. The T-70 didn't break, he just didn't want to take a chance.
Old Nov 7, 2006 | 05:54 PM
JG-Fabrications's Avatar
Default Re: (FUCATYPR)
hell at that price if my intercooler core and everything else didnt cost so much I would throw one on just for $h!ts and giggles (see if we can make 800whp on it lol)
-James
Old Nov 7, 2006 | 06:02 PM
Hir0's Avatar
Default Re: Anyone using... SSAC T3 Super 70... Already searched and read the SSAC Thread!!! (blindingxenon)
Read This Thread!
https://honda-tech.com/zero...age=1
The fitting is a 4-AN Inlet Fitting like this you could use a 3 - AN too
http://store.function-7.com/ca...id/48
A couple of Dyno graphs of the ebay kits
http://forums.evans-tuning.com...=ebay
my bad dude i fucked up
Modified by Hir0 at 7:45 PM 11/7/2006
Modified by Hir0 at 8:25 PM 11/7/2006
Old Nov 7, 2006 | 06:05 PM
mrbsponge's Avatar
mustang guys love these things
Old Nov 7, 2006 | 06:07 PM
B A N N E D
Default Re: Anyone using... SSAC T3 Super 70... Already searched and read the SSAC Thread!!! (Hir0)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hir0 &raquo;</TD></TR><TR><TD CLASS="quote">READ THIS THREAD!
https://honda-tech.com/zerothread/1804206
The fitting is a 4-AN Inlet Fitting like this retards nd rejects
what a smart guy.. send me a link to my own thread.. LMAO
Old Nov 7, 2006 | 06:13 PM
beepy's Avatar
Restrictors should be used in any turbo that doesn't have integral restrictors. Turbos aren't meant to be oiled from the main gallery.
It is easy to overoil a turbo but difficult to underoil one. Well, journal bearing turbos, at least.
Old Nov 7, 2006 | 06:46 PM
Hir0's Avatar
lalalala
Old Nov 7, 2006 | 06:53 PM
B A N N E D
if you read my title you wouldnt have posted that thread.. ive read that thread up and down. Alot of talk but no real answers in therer.
Old Nov 7, 2006 | 07:05 PM
HiProfile's Avatar
I'd suggest looking at this page for maps that should be similar -
http://majesticturbo.com/c-maps-6.html
An 84mm exducer on the compressor wheel is more like a t58 (ts04), not a t3. I'd be even more wary about the t3-flange claim than the shaft's balance. You should be able to make it last a while with a restrictor. As said above, oem turbo cars don't exactly supply the turbo oil right after the pump/filter. People here have cooked real garrett/turbonetics/etc turbos because they didn't feel a mass flow of oil pressurized to 40-80psi was enough for the turbo.
Spool time for this on a honda should be like any other T4 - press the gas, call & talk to a friend or three, then get massive boost.
Old Nov 7, 2006 | 07:23 PM
Hir0's Avatar
Default Re: Anyone using... SSAC T3 Super 70... Already searched and read the SSAC Thread!!! (HiProfile)
I say get the damnd thing and stop being so scary ***** foot
Old Nov 7, 2006 | 07:40 PM
B A N N E D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hir0 &raquo;</TD></TR><TR><TD CLASS="quote">I say get the damnd thing and stop being so scary ***** foot</TD></TR></TABLE>
I say why dont you do it.. See im doing this thing called Research. Because i dont have money coming out of my ***. so i am searching for what i want. this doesnt look like it will fit me. But im sure this thread will help othrers out there that want to run a turbo on a budget. so if you have nothing to contribute to this thread please dont respond.
Old Dec 12, 2006 | 03:53 PM
wrx'n you's Avatar
Default Re: Anyone using... SSAC T3 Super 70... Already searched and read the SSAC Thread!!! (chasemyhonda)
bump from the dead cause i wanna know the spool time for this turbo also...
Old Jan 14, 2007 | 07:04 PM
SpeedwaySlick's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chasemyhonda &raquo;</TD></TR><TR><TD CLASS="quote">
im sure this thread will help othrers out there </TD></TR></TABLE>
This thread was helpful. I'm looking for a SSAC turbo to replace my t3 50 trim, with something that will spool up about as quickly. It's clear from this thread that I don't want a super 70.
Old Jan 19, 2007 | 04:08 AM
Turboed1's Avatar
Aaah...The venerable KKK K27 yet again. Hasn't anybody started thinking about why the compressor housing (the backplate even says K27 on the back) has 6mm bolts with 10mm heads attaching it,instead of the 5/16" w/ 1/2" head every Garrett/'netics and ITS uses? Plain and simple. It's an ancient european design...copied,copied and then copied of the copies yet again...
bobafreaklx
May 26, 2007 07:46 AM
KevronsEG
Dec 9, 2006 03:31 PM
geezer_187
Apr 3, 2006 06:21 PM
DavidR
Jun 2, 2005 01:00 PM
D21X
Jun 11, 2003 12:58 AM
