help....my 99 si wont start
when i try to start up the car, i dont hear the fuel pump prime and it doesnt crank... i checked the fuses and i took out the alarm and still nothingand i changed the battery also.. what do you guys think it is?
thanks in advance
thanks in advance
I had the same problem with my gsr..
for me, it was the relay for the fuel pump..
same symptoms for me..i wouldnt hear my fuel pump...then no crank over
I think that it is probly that, u never kno with hondas though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marshun »</TD></TR><TR><TD CLASS="quote">does your dash lights come on when you put the car into the "ON" position?</TD></TR></TABLE>
thats what I was thinking
If the starter isnt turning either check the ignition wire from the column to the starter... and if its turning but not cranking , try rolling the car a little bit to get the starter to bite? its worth a try
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ej1_coupe »</TD></TR><TR><TD CLASS="quote">
thats what I was thinking</TD></TR></TABLE>
yup. gotta think logically. thats all
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 123lbc »</TD></TR><TR><TD CLASS="quote">when i try to start up the car, i dont hear the fuel pump prime and it doesnt crank... i checked the fuses and i took out the alarm and still nothingand i changed the battery also.. what do you guys think it is?
thanks in advance</TD></TR></TABLE>
Need just alittle more info to help you out. Do you have power at all? Does the motor try to turn over at all If not can you here the starter clicking.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 123lbc »</TD></TR><TR><TD CLASS="quote">it has power......my pops fixed the problem already</TD></TR></TABLE>
so how did he fix it?
ground wires....one was lose and one was bad....when it came out of the body shop i guess they didnt tighten it after they sprayed my enginebay
alonzo_civic
Feb 24, 2008 02:37 PM
TheIntegraGuy
Aug 18, 2005 05:57 PM
