EM1 gone WILD!! HELP!!
First off my car wont start. The motor wont crank. Not sure why But I think its because of my alarm.
Its a remote start. Usually when I go start the car or unlock the doors with the remote the car would just unlock it or turn on the car.
But not the lights blink im not sure why
When I go start the car I hear the fuel pump like always but now the lights blink and the guage cluster blinks also im not sure why it started to do this all of a sudden. The car doesnt crank at all ignition and everything else works fine and turns on fine
I want to know why my car is doing this all of a sudden
is it trying to tell me something like a my starter when out or something?
Re: EM1 gone WILD!! HELP!! (OoBryan)
Jacked this off someone else's thread...
The remote looks like that except it says Two way security on the bottom and not what is in the pic. Cause I dont know what brand mine is.
Modified by OoBryan at 4:24 PM 4/25/2005
Depending on your alarm, it may have disabled your starter
i dotn know about your alarm but if mine is going off it disables the starter, and ive also had problems with it when trying to re program it, it was like stuck on disable
Did you check your battery tho by any chance?
Re: EM1 gone WILD!! HELP!! (athoughts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts »</TD></TR><TR><TD CLASS="quote">Depending on your alarm, it may have disabled your starter
Did you check your battery tho by any chance? </TD></TR></TABLE>
Yes I checked the battery. I even unplugged it to reset the ECU and alarm didnt work though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OoBryan »</TD></TR><TR><TD CLASS="quote">Bump for some help!</TD></TR></TABLE>
try jumping the car. If that doesn't work check the wiring with the starter. Why did you get the remote starter? They're usually a pain to work with a manual transmission...and you live in phoenix.
Re: (Sijray21)
check the wiring by your clutch pedal..
if its an em1, its a standard so they would have had to bypass the clutch to start the car without actually being in it. if they tapped into the switch by the clutch pedal you could have possibly pulled it out while driving it.
Re: (sidesi)
Alright thanks for all the input guys. I actually got the car started yesterday. I just fucked with some wires from the alarm box lol
kaychi
09-29-2007 05:40 PM
