Car Shaking in 3rd and 4th
Old Nov 7, 2006 | 10:25 AM
koulaid's Avatar
Default Car Shaking in 3rd and 4th
I just got done installing a new passenger side axel on my b16a eg. When im in 3rd gear and accelerate the car shakes(dosnt shake really hard though, enough just for me to feel and things to vibrate in my car). wat could it be?
Old Nov 7, 2006 | 11:03 AM
instructor74's Avatar
Default Re: Car Shaking in 3rd and 4th (koulaid)
You could have gotten a bad remanufactured axle. Did you get one that had a new outer joint or on that was just repaired? You could also have lost a wheel weight. I chased this problem for a year before the place I got the bad drive shaft replaced it under warranty
Old Nov 7, 2006 | 11:07 AM
koulaid's Avatar
Default Re: Car Shaking in 3rd and 4th (instructor74)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">You could have gotten a bad remanufactured axle. Did you get one that had a new outer joint or on that was just repaired? You could also have lost a wheel weight. I chased this problem for a year before the place I got the bad drive shaft replaced it under warranty</TD></TR></TABLE>
i think it was just remanufactured.. not sure .. thats what they told me. plus it was a 94 gsr axle. it fits perfectly but after i was done it just started shaking. o yea and i forgot to add that its a b16a2 tranny. if it makes any difference
Old Nov 7, 2006 | 12:15 PM
the trans doesn't make a difference. Any shaft you get will be remanufactured.....but some are better then others. Tell the parts store you want the cv axle replaced under warranty. Tell them you want a cv axle that has a new outer joint on it........ you might pay a little bit more. Be ready to get one that could be better, the same, or worse. If that doesn't fix it you could pony up the extra $$ and get a reman from the dealer.
Old Nov 7, 2006 | 12:25 PM
koulaid's Avatar
ok thx man...ill do that and repost when i have it done
Old Nov 7, 2006 | 01:22 PM
B16b-EJ8's Avatar
I'm also going to bank on the axle being a defective reman. take it back and get another one till it goes away.
b18c eJ1
Feb 25, 2007 12:15 PM
opiumdaze
Feb 13, 2006 09:50 PM
MrMayhem
May 20, 2004 12:54 PM
eTec
Apr 9, 2002 11:36 PM
